U mm. I accidentally enabled Nstreme on a remote station. I have one DSL connection, and I serve it to a MK AP and one client links to it from about a block and a half down the side walk. I was upgrading the OS (from about 400 miles away), that took a while but, they did come around. I set Ntsreme on the client and set the framer policy to dynamic and framer limit to the default 3200 then I lost connection. It even lost wireless connection. The device
has bridge enabled and has worked reliably until I did this. Can I just set the AP to the same settings? Will It work ? I could use some suggestions. The boards are RB112 on the AP and either a RB112 or 133. I had sucessfully upgraded both devices remotely. to v2.9.50
The only thing you need to do is to turn on nstream on the ap with the same settings and the link are going to start working again.
You were right thanks, one other problem has anyone heard of losing passwords from upgrading the firmware to v2.9.50. I have access through my Dude, but I have no luck trying to access the device by any other means,telnet, mac-tel-winbox,etc
If you right klick on the unit in dude and then go to tool winbox are you able to connect then?
I have not at all have that problem.
