Hi Forum
Having hard time with routeros,
coming from ubnt world it was very easy to use 2 or 3 wan connections to combine the speed and nat / port forward,
problem is that they have max 8 port router, so i got now 1100 ahx2 and trying to figure out how to !
I have 1 VDSL 50/5 static ip - 1 VDSL 50/5 dynamic ip - 1 VDSL 30/3 dynamic ip
Is there any easy way to combine there traffic lan1+lan2+lan3 to ports 4-11 ??
It looks like you want to make load balancer.
In MikroTik there are at least 3 ways to implement it PCC,NTH and ECMP. It depends what you need.
I recommend you to check out this videos:
https://www.youtube.com/watch?v=AqXkBkEaS5I from my Partner Alejandro Teixeira
Or this other from another trainer Thomas Kirnak
https://www.youtube.com/watch?v=67Dna_ffCvc
My recommendation in the first place understand and later apply, don’t try to jump to implement in the first moment.
Thank you ! I try !!
