Closed
First, who is user Estiaan? Give more information about network - what connection use to internet, local network… then post here your firewall rules.
And better stay with last bugfix version 6.32.4 - do you prefer stability, or want to be beta tester?
Closed
guys i need some help i really really need some help please
you have too complicated firewall, in my opinion many many ot these rules is useless and do absolutely nothing. nothing good at least. i don’t know what is easy - to edit (disabled) they one by one, or rewrite all from zero. about red line i have no answer, maybe some who has more experience with mikrotik will explain.
First, never use release candidate(RC versions of ROS) in your production.
Second, disable firewall rules and then check.I suggest you to erase current config(backup first, ofc) and to configure your device from scratch.
If you still get this problem with new config, its time to netinstall.
