hi how can create folder in file by script
hi how i can create folder in file by script :slight_smile: :slight_smile: :slight_smile:
Why not try to use fetch upload command on localhost, if it’s create the directory.
http://wiki.mikrotik.com/wiki/Manual:Tools/Fetch#Examples
