Hi, Newbie here, please crticize.
Hi, im i newbie and bought some Mikrotik devices. I currently have 2 HAP AC2 to work as access points. One Hex S to work as main router. One Hex that i will not use for the moment. My setup would be something like this.
HEXS as main router. Use Ports 4 and 5 to conect to both APs, one to the poe eth port (5) that will only be used as a wireless access point, and one AP connected to port eth 4 that will be used to give out wireless signal and i will probably use all eth ports on it.
I wanna have 4 VLANS, main, guest, iot, cameras.
After crying for some time regretting of having bought something so user unfriendly and with so many granualr option for setup, i spent the weekend researching and setting up the HEXs. I will now paste here the setting and i please ask you what do you think? Im particularly worried about firewall rules. In my main VPN i will have a server and a NAS that i dont want exposed. Lets forget for all the rest of the setup for now and let just focus on the HEXs
# 2025-11-05 13:56:10 by RouterOS 7.16.1
# software id = 7KBA-8631
# model = RB760iGS
# serial number = XXXXXXXX
add name=bridge-lan vlan-filtering=yes
set [ find default-name=ether1 ] comment=WAN_Internet
/interface vlan
add interface=bridge-lan name=vlan10-main vlan-id=10
add interface=bridge-lan name=vlan20-guest vlan-id=20
add interface=bridge-lan name=vlan30-iot vlan-id=30
add interface=bridge-lan name=vlan40-cams vlan-id=40
add name=WAN_Interfaces
add name=LAN_Interfaces
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool2 ranges=192.168.20.2-192.168.20.254
add name=dhcp_pool3 ranges=192.168.30.2-192.168.30.254
add name=dhcp_pool4 ranges=192.168.40.2-192.168.40.254
add address-pool=dhcp_pool1 interface=vlan10-main name=dhcp1
add address-pool=dhcp_pool2 interface=vlan20-guest name=dhcp2
add address-pool=dhcp_pool3 interface=vlan30-iot name=dhcp3
add address-pool=dhcp_pool4 interface=vlan40-cams name=dhcp4
add bridge=bridge-lan interface=ether2 pvid=10
add bridge=bridge-lan interface=ether4 pvid=10
add bridge=bridge-lan interface=ether5 pvid=10
add bridge=bridge-lan interface=ether3 pvid=10
/interface bridge vlan
add bridge=bridge-lan comment="VLAN10 (Main)" tagged=bridge-lan untagged=\
    ether2,ether3,ether4,ether5 vlan-ids=10
add bridge=bridge-lan comment="VLAN20 (Guests)" tagged=bridge-lan,ether4,ether5 \
    vlan-ids=20
add bridge=bridge-lan comment="VLAN30 (IOT)" tagged=bridge-lan,ether4,ether5 \
    vlan-ids=30
add bridge=bridge-lan comment="VLAN40 (Camaras)" tagged=bridge-lan,ether4,ether5 \
    vlan-ids=40
add interface=ether1 list=WAN_Interfaces
add interface=vlan10-main list=LAN_Interfaces
add interface=vlan20-guest list=LAN_Interfaces
add interface=vlan30-iot list=LAN_Interfaces
add interface=vlan40-cams list=LAN_Interfaces
add address=192.168.10.1/24 interface=vlan10-main network=192.168.10.0
add address=192.168.20.1/24 interface=vlan20-guest network=192.168.20.0
add address=192.168.30.1/24 interface=vlan30-iot network=192.168.30.0
add address=192.168.40.1/24 interface=vlan40-cams network=192.168.40.0
add address=192.168.10.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.10.1
add address=192.168.20.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.20.1
add address=192.168.30.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.30.1
add address=192.168.40.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.40.1
add action=accept chain=input comment="Accept Established/Related Input" \
    connection-state=established,related connection-type=""
add action=drop chain=input comment="Drop Invalid Input" connection-state=\
    invalid
add action=accept chain=input comment="Allow ICMP to Router" connection-type="" \
    protocol=icmp
add action=accept chain=input comment="Allow Main LAN (vlan10-main) to Router" \
    in-interface=vlan10-main
    "Allow DNS (UDP) from vlan20-guest to Router" dst-port=53 in-interface=\
    vlan20-guest protocol=udp
    "Allow DNS (TCP) from vlan20-guest to Router" dst-port=53 in-interface=\
    vlan20-guest protocol=tcp
    "Allow DNS (UDP) from vlan30-iot to Router" dst-port=53 in-interface=\
    vlan30-iot protocol=udp
    "Allow DNS (TCP) from vlan30-iot to Router" dst-port=53 in-interface=\
    vlan30-iot protocol=tcp
add action=drop chain=input comment="Drop other LAN traffic to Router" \
    in-interface-list=LAN_Interfaces
add action=drop chain=input comment="Drop ALL from WAN_Interfaces to Router" \
    in-interface-list=WAN_Interfaces
add action=accept chain=forward comment="Accept Established/Related Forward" \
add action=drop chain=forward comment="Drop Invalid Forward" connection-state=\
    invalid
add action=drop chain=forward comment="Block vlan40-camaras to WAN" \
    in-interface=vlan40-cams out-interface-list=WAN_Interfaces
add action=accept chain=forward comment="Allow LAN_Interfaces to WAN_Interfaces" \
    in-interface-list=LAN_Interfaces out-interface-list=WAN_Interfaces
add action=drop chain=forward comment="Drop All Other Forward"
add action=masquerade chain=srcnat comment="Masquerade LANs to WANs" \
/system clock
set time-zone-name=America/Buenos_Aires
/system note
set show-at-login=no
# 2025-11-05 135610 by RouterOS 7.1.txt
Displaying # 2025-11-05 135610 by RouterOS 7.1.txt.
Why allow DNS traffic to the router, while clients will use “dns-server=1.1.1.1,8.8.8.8”?
Though not being incorrect, you can change this:
To this:
add action=drop chain=input comment="Drop other traffic to Router"
Any reason for sticking to 7.16.1 (while the current stable is 7.18.2)?
