HI,NORMIS do you have time?
can you login my router see if my router setting was safe?
I’m headache with setting it up, if you can i send my login info to support.
thanks in advance.
Contact and hire MikroTik certified consultants,
http://www.mikrotik.com/consultants.html
or post your configurations here for evaluation (remove sensitive information first)
You can also post what type of router or service you want to provide?
Just put the configuration of you router H/W, ( must after install the MK and if you don’t want to setup a hotspot or wireless service) and send me a SMS to my cell phone at +8801716488912. I will make myself in my virtual server for your service and send you a backup copy of it.
Rafiq…
hi,I have rb532a r5, wireless card r52, 15db omni antenna .
I want configuration router as:
first two port for loading WAN (ECMP Routing )
third port for lan with 192.168.0.1/24
hotspot(i don’t want hotspot user can access to my router anyway and cann’t intercommunion with my local lan)
secure router protect customer
please send your backup copy to:
FTP: claol.com
user:temp@claol.com
password:123456
everyone want to help me is welcome.
thanks!!!
Dear channingzou,
I used a p-III with 3 lan card.
Please discurd IP address 192.168.2.10.. and replace all other IP address as you need.
I am not experience with HOTSPOT. Already a copy of this backup is sent to your ftp. This is for others.
I think It will help you.
Rafiq…
MikroTik-07082007.rar (4.62 KB)
Probably backup file will not be restored correctly. It is better to use export file.
hi,sergejs will make export file upload to your website let everyone download?
Here is the export file ...
Rafiq...
aug/07/2007 17:50:24 by RouterOS 2.9.27
software id = 9EK0-FJT
/ interface ethernet
set Lan name="Lan" mtu=1500 mac-address=00:08:54:34:6A:96 arp=enabled
disable-running-check=yes auto-negotiation=yes full-duplex=yes
cable-settings=default speed=100Mbps comment="" disabled=no
set Wan1 name="Wan1" mtu=1500 mac-address=00:E0:4D:49:87:05 arp=enabled
set Wan2 name="Wan2" mtu=1500 mac-address=00:10:4B:0E:E8:D2 arp=enabled
/ interface l2tp-server server
set enabled=no max-mtu=1460 max-mru=1460
authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption
/ interface pptp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=mschap1,mschap2
keepalive-timeout=30 default-profile=default-encryption
/ ip accounting
set enabled=no account-local-traffic=no threshold=256
/ ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
/ ip service
set telnet port=23 address=0.0.0.0/0 disabled=no
set ftp port=21 address=0.0.0.0/0 disabled=no
set www port=80 address=0.0.0.0/0 disabled=no
set ssh port=22 address=0.0.0.0/0 disabled=no
set www-ssl port=443 address=0.0.0.0/0 certificate=none disabled=yes
/ ip upnp
set enabled=no allow-disable-external-interface=yes show-dummy-rule=yes
/ ip arp
/ ip socks
set enabled=no port=1080 connection-idle-timeout=2m max-connections=200
/ ip dns
set primary-dns=0.0.0.0 secondary-dns=0.0.0.0 allow-remote-requests=no
cache-size=2048KiB cache-max-ttl=1w
/ ip traffic-flow
set enabled=no interfaces=all cache-entries=4k active-flow-timeout=30m
inactive-flow-timeout=15s
/ ip address
add address=192.168.2.10/24 network=192.168.2.0 broadcast=192.168.2.255
interface=Lan comment="added by setup" disabled=no
add address=177.66.202.2/24 network=177.66.202.0 broadcast=177.66.202.255
interface=Wan1 comment="" disabled=no
add address=177.66.203.3/24 network=177.66.203.0 broadcast=177.66.203.255
interface=Wan2 comment="" disabled=no
add address=192.168.17.1/24 network=192.168.17.0 broadcast=192.168.17.255
/ ip proxy
set enabled=no port=8080 parent-proxy=0.0.0.0:0 maximal-client-connecions=1000
maximal-server-connectons=1000
/ ip proxy access
add dst-port=23-25 action=deny comment="block telnet & spam e-mail relaying"
disabled=no
/ ip neighbor discovery
set Lan discover=yes
set Wan1 discover=yes
set Wan2 discover=yes
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.2.1 scope=255 target-scope=10
add dst-address=0.0.0.0/0 gateway=177.66.202.1 check-gateway=ping scope=255
target-scope=10 routing-mark=wan1 comment="" disabled=no
add dst-address=0.0.0.0/0 gateway=177.66.203.1 check-gateway=ping scope=255
target-scope=10 routing-mark=wan2 comment="" disabled=no
/ ip firewall mangle
add chain=prerouting src-address=192.168.17.0/24 action=mark-routing
new-routing-mark=wan1 passthrough=yes comment="" disabled=no
new-routing-mark=wan2 passthrough=yes comment="" disabled=no
/ ip firewall nat
add chain=srcnat src-address=192.168.17.0/24 action=masquerade comment=""
disabled=no
/ ip firewall connection tracking
set enabled=yes tcp-syn-sent-timeout=5s tcp-syn-received-timeout=5s
tcp-established-timeout=1d tcp-fin-wait-timeout=10s
tcp-close-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-time-wait-timeout=10s tcp-close-timeout=10s udp-timeout=10s
udp-stream-timeout=3m icmp-timeout=10s generic-timeout=10m
tcp-syncookie=no
/ ip firewall filter
add chain=input connection-state=invalid action=drop comment="Drop Invalid
connections" disabled=no
add chain=input connection-state=established action=accept comment="Allow
Established connections" disabled=no
add chain=input protocol=udp action=accept comment="Allow UDP" disabled=no
add chain=input protocol=icmp action=accept comment="Allow ICMP" disabled=no
add chain=input src-address=192.168.0.0/24 action=accept comment="Allow access
to router from known network" disabled=no
add chain=input src-address=192.168.2.0/24 action=accept comment="Allow access
to router from here " disabled=no
add chain=input src-address=192.168.17.0/24 action=accept comment="Allow
access to router from here " disabled=no
add chain=input action=drop comment="Drop anything else" disabled=no
add chain=forward protocol=tcp connection-state=invalid action=drop
comment="drop invalid connections" disabled=no
add chain=forward connection-state=established action=accept comment="allow
already established connections" disabled=no
add chain=forward connection-state=related action=accept comment="allow
related connections" disabled=no
add chain=forward src-address=0.0.0.0/8 action=drop comment="" disabled=no
add chain=forward dst-address=0.0.0.0/8 action=drop comment="" disabled=no
add chain=forward src-address=127.0.0.0/8 action=drop comment="" disabled=no
add chain=forward dst-address=127.0.0.0/8 action=drop comment="" disabled=no
add chain=forward src-address=224.0.0.0/3 action=drop comment="" disabled=no
add chain=forward protocol=udp action=jump jump-target=udp comment=""
disabled=no
add chain=forward protocol=icmp action=jump jump-target=icmp comment=""
disabled=no
add chain=tcp protocol=tcp dst-port=69 action=drop comment="deny TFTP"
disabled=no
add chain=tcp protocol=tcp dst-port=111 action=drop comment="deny RPC
portmapper" disabled=no
add chain=tcp protocol=tcp dst-port=135 action=drop comment="deny RPC
add chain=tcp protocol=tcp dst-port=137-139 action=drop comment="deny NBT"
disabled=no
add chain=tcp protocol=tcp dst-port=445 action=drop comment="deny cifs"
disabled=no
add chain=tcp protocol=tcp dst-port=2049 action=drop comment="deny NFS"
disabled=no
add chain=tcp protocol=tcp dst-port=12345-12346 action=drop comment="deny
NetBus" disabled=no
add chain=tcp protocol=tcp dst-port=20034 action=drop comment="deny NetBus"
disabled=no
add chain=tcp protocol=tcp dst-port=3133 action=drop comment="deny
BackOriffice" disabled=no
add chain=tcp protocol=tcp dst-port=67-68 action=drop comment="deny DHCP"
disabled=no
add chain=udp protocol=udp dst-port=69 action=drop comment="deny TFTP"
disabled=no
add chain=udp protocol=udp dst-port=111 action=drop comment="deny PRC
add chain=udp protocol=udp dst-port=135 action=drop comment="deny PRC
add chain=udp protocol=udp dst-port=137-139 action=drop comment="deny NBT"
disabled=no
add chain=udp protocol=udp dst-port=2049 action=drop comment="deny NFS"
disabled=no
add chain=udp protocol=udp dst-port=3133 action=drop comment="deny
add chain=icmp protocol=icmp icmp-options=0:0 action=accept comment="drop
add chain=icmp protocol=icmp icmp-options=3:0 action=accept comment="allow
add chain=icmp protocol=icmp icmp-options=3:1 action=accept comment="allow
add chain=icmp protocol=icmp icmp-options=4:0 action=accept comment="allow
source quench" disabled=no
add chain=icmp protocol=icmp icmp-options=8:0 action=accept comment="allow
echo request" disabled=no
add chain=icmp protocol=icmp icmp-options=11:0 action=accept comment="allow
time exceed" disabled=no
add chain=icmp protocol=icmp icmp-options=12:0 action=accept comment="allow
parameter bad" disabled=no
add chain=icmp action=drop comment="deny all other types" disabled=no
/ ip firewall service-port
set ftp ports=21 disabled=no
set tftp ports=69 disabled=no
set irc ports=6667 disabled=no
set h323 disabled=yes
set quake3 disabled=no
set gre disabled=yes
set pptp disabled=yes
/ ip ipsec proposal
add name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=30m
lifebytes=0 pfs-group=modp1024 disabled=no
/ ip web-proxy
set enabled=no src-address=0.0.0.0 port=3128 hostname="proxy"
transparent-proxy=no parent-proxy=0.0.0.0:0
cache-administrator="webmaster" max-object-size=4096KiB cache-drive=system
max-cache-size=none max-ram-cache-size=unlimited
/ ip web-proxy access
disabled=no
/ ip web-proxy cache
add url=":cgi-bin \?" action=deny comment="don't cache dynamic http pages"
disabled=no
/ system logging
add topics=info prefix="" action=memory disabled=no
add topics=error prefix="" action=memory disabled=no
add topics=warning prefix="" action=memory disabled=no
add topics=critical prefix="" action=echo disabled=no
/ system logging action
set memory name="memory" target=memory memory-lines=100 memory-stop-on-full=no
set disk name="disk" target=disk disk-lines=100 disk-stop-on-full=no
set echo name="echo" target=echo remember=yes
set remote name="remote" target=remote remote=0.0.0.0:514
/ system upgrade mirror
set enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0
check-interval=1d user=""
/ system clock dst
set dst-delta=+00:00 dst-start="jan/01/1970 00:00:00" dst-end="jan/01/1970
00:00:00"
/ system watchdog
set reboot-on-failure=yes watch-address=none watchdog-timer=yes
no-ping-delay=5m automatic-supout=yes auto-send-supout=no
/ system console
add term="" disabled=no
set FIXME term="linux" disabled=no
/ system console screen
set line-count=25
/ system identity
set name="MikroTik"
/ system note
set show-at-login=yes note=""
/ ppp profile
set default name="default" use-compression=default use-vj-compression=default
use-encryption=default only-one=default change-tcp-mss=yes comment=""
set default-encryption name="default-encryption" use-compression=default
use-vj-compression=default use-encryption=yes only-one=default
/ ppp aaa
set use-radius=no accounting=yes interim-update=0s
/ queue type
set default name="default" kind=pfifo pfifo-limit=50
set ethernet-default name="ethernet-default" kind=pfifo pfifo-limit=50
set wireless-default name="wireless-default" kind=sfq sfq-perturb=5
sfq-allot=1514
set synchronous-default name="synchronous-default" kind=red red-limit=60
red-min-threshold=10 red-max-threshold=50 red-burst=20 red-avg-packet=1000
set hotspot-default name="hotspot-default" kind=sfq sfq-perturb=5
sfq-allot=1514
add name="default-small" kind=pfifo pfifo-limit=10
/ user
add name="admin" group=full address=0.0.0.0/0 comment="system default user"
disabled=no
/ user group
add name="read" policy=local,telnet,ssh,reboot,read,test,winbox,password,web,!f
tp,!write,!policy
add name="write" policy=local,telnet,ssh,reboot,read,write,test,winbox,password
,web,!ftp,!policy
add name="full" policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbo
x,password,web
/ user aaa
set use-radius=no accounting=yes interim-update=0s default-group=read
/ radius incoming
set accept=no port=1700
/ driver
/ snmp
set enabled=no contact="" location=""
/ snmp community
set public name="public" address=0.0.0.0/0 read-access=yes
/ tool bandwidth-server
set enabled=yes authenticate=yes allocate-udp-ports-from=2000 max-sessions=10
/ tool mac-server ping
set enabled=yes
/ tool e-mail
set server=0.0.0.0 from="<>"
/ tool sniffer
set interface=all only-headers=no memory-limit=10 file-name="" file-limit=10
streaming-enabled=no streaming-server=0.0.0.0 filter-stream=yes
filter-protocol=ip-only filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535
/ tool graphing
set store-every=5min
/ routing ospf
set router-id=0.0.0.0 distribute-default=never redistribute-connected=no
redistribute-static=no redistribute-rip=no redistribute-bgp=no
metric-default=1 metric-connected=20 metric-static=20 metric-rip=20
metric-bgp=20
/ routing ospf area
set backbone area-id=0.0.0.0 type=default translator-role=translate-candidate
authentication=none prefix-list-import="" prefix-list-export=""
disabled=no
/ routing bgp
set enabled=no as=1 router-id=0.0.0.0 redistribute-static=no
redistribute-connected=no redistribute-rip=no redistribute-ospf=no
/ routing rip
set redistribute-static=no redistribute-connected=no redistribute-ospf=no
redistribute-bgp=no metric-static=1 metric-connected=1 metric-ospf=1
metric-bgp=1 update-timer=30s timeout-timer=3m garbage-timer=2m
I know it is too big .. but I cannot upload this file with various extension.
hi,Rafiq
I probably try backup file first ,if I need some more help do you have time login to my router to do it?
thanks a lot !!!
I have tried backup ,it doesn’t work ,still in same was , I use rc1
