i had 2 adsl routers 1 vs 2 m and the second has the same speed
so i has mikrotik v 3.30
wanna merage them to has 4 m speed
and wanna know coz i has about 20 users thy use download much that had a bad effects on browsing and Surf the Internet so how can i save a good download with a speed browsing ? i mean if there away to separate (download by about 2 m and browsing and surf internet by 2 m)
not routers i p is 192.168.1.1 and 192.168.2.1
with lan out 10.10.10.1
thank you
