Hi...there
Hi, guys. Can tell anyone how to install mikrotik from boot CD, without formating computer. I try to install Mitrotik 2.7, but, it requires formatting HD of computer. I thank everyone response to me.
Greetings!
I have a few spare hard drives that I use for this. Disconnect/remove your permanent hard drive, connect/install new drive. Like a new computer! When you are done, reinstall/connect your original drive, and its like nothing happened. :smiley:
EDIT: Maybe I misunderstood the goal. You should be able to create a bootable CD from an image with your CD writer software. My software has a “create CD from image” selection. It will ask for an *.iso file. Use the iso for the bootable CD, and it should make you a bootable CD. Also, insure the disk boot order is CD - Hard drive in the bios settings.
SurferTim is correct,
But why dont you use the latest version. the ISO is freely available on the website
http://www.mikrotik.com/download/mikrotik-3.10.iso
Mikrotik does not work with another operating system installed on the same hard drive. It will always try to format and install. Cant dual boot with mt.
