Hello
I was wondering if there was a script to Auto hide an ip or an ip range from the hosts list in Hotspot all the time
I have read on the scripting http://wiki.mikrotik.com/wiki/Scripting but i am still lost
Hello
No. The moment the hotspot sees a packet, they will show up again. Running a script scheduled every second is a great way introducing problems and keeping the router too busy to route packets when you need it to. The solution to your issue is not cosmetic (hide the hosts), but to change your network design so that they aren’t behind the Hotspot in the first place. Without knowing anything else about your network VLANs can possibly be used in that regard.
Hello, thanks for the reply, well lets say it is a lab environment, i just wanna test it this way not for a productive environment
Can you provide me with the script please
By the way will that script hide it only or kick the host ?
Thank you again
It will kick the host.
/ip hotspot host remove where address~"your pattern here"
Then schedule that to run periodically.
I have no idea why you’d even test it in a lab given how bad of an idea it is.
