Hide ip addresses on gre tunnel
Goodday everyone.
as a first sorry for my bad english.
However, I can read and understand English, but I can’t write very well, so I type my message in Google translate and have it translate the text from Dutch to English
I have mikrotik routeros 6.49.7 running on my proxmox vm server.
on this router I have configured a hamnet (radio transmit amatuer) connection according to the following script.
add comment=HamNet name=bridge
/interface gre
add allow-fast-path=no comment="Link naar GW-44-137" !keepalive name=gre09
gw-44-137-vpn.ampr.org
/routing bgp instance
set default as=4220408304 router-id=44.137.83.78 routing-table=hamnet
add address=44.137.83.78/28 interface=bridge network=44.137.7.96
add address=44.137.61.34/30 interface=gre09 network=44.137.61.32
add distance=1 dst-address=44.137.83.64/28 gateway=bridge pref-src=44.137.83.78 routing-mark=hamnet scope=10
add distance=1 dst-address=44.137.61.32 gateway=gre09 pref-src=44.137.61.34 routing-mark=hamnet scope=10
/ip route rule
add src-address=44.0.0.0/9 table=hamnet
add src-address=44.128.0.0/10 table=hamnet
add dst-address=44.0.0.0/9 table=hamnet
add dst-address=44.128.0.0/10 table=hamnet
/routing bgp network
add network=44.137.83.64/28
/routing bgp peer
add hold-time=15s in-filter=hamnet-in name=gw-44-137 nexthop-choice=force-self out-filter=hamnet-out remote-address=44.137.61.33 remote-as=4220406100 ttl=1
/routing filter
add bgp-communities=44137:10050 chain=hamnet-in set-bgp-local-pref=50
add bgp-communities=44137:10200 chain=hamnet-in set-bgp-local-pref=200
add bgp-communities=65535:0 chain=hamnet-in comment=RFC8326 set-bgp-local-pref=0
add chain=hamnet-in set-pref-src=44.137.83.78
add action=accept chain=hamnet-in prefix=44.0.0.0/8 prefix-length=8-32
add action=accept bgp-as-path=4220406100 chain=hamnet-in prefix=0.0.0.0/0
add action=discard chain=hamnet-in
add action=accept chain=hamnet-out prefix=44.0.0.0/8 prefix-length=8-32
add action=accept bgp-as-path=4220406100 chain=hamnet-out prefix=0.0.0.0/0
add action=discard chain=hamnet-out
now I can neatly do a tracert from my router to other hamnet users and my router can also be reached.
but devices connected to the lan side and that therefore have a local ip address cannot go outside via the hamnet connection.
this is probably because they see their local ip address (192.168.200.x) on the hamnet side and do not know what to do with it.
the question now is whether and if so how can I ensure that when traffic goes out through the gre tunnel, the ip locale address is made invisible / is replaced by eg 44.137.83.78 so that hamnet sees an ip address that they know?
Before even getting to the topic, what are the firewall rules of your CHR? Ideally, export the configuration and post it after obfuscating all public IP addresses, serial number, and any logins to external services.
I would like to tell you what is configured on chr.
However, outside the script, I configured exactly 2 lines for the ports 8006 and 3128.
so if you tell me how or where i can find the chr ruls i would love to share them with you but unfortunately i’m not an exeprt and it’s purely hobby.
So unfortunately I don’t know everything.
That’s what I was afraid of. Unlike the SOHO-grade devices, the CHR has no firewall rules by default because it is assumed that only people who know something about networking use it. And your CHR not only runs on a public IP but it even acts as a gateway to another network, so you shouldn’t have even connected it to the internet before setting up a firewall.
So the correct procedure now would be to remove this one, install a new one from the installation image while the hardware server would be disconnected from the internet, install a set of firewall rules preventing access to its management interfaces from anywhere else than from a short list of permitted public IP addresses, or even better, only via a VPN connection (which may be the only option if you don’t have a public IP address where you connect from to manage that CHR). Although all vendors do their best to make the management services secure, you can never be 100% sure and there have been many cases in the past where malware could get to routers without knowing the user credentials due to vulnerabilities (bugs in the code).
The minimum firewall would like as follows:
/ip firewall address-list
add list=mgmt-ips address=your.home.public.ip
add chain=input connection-state=established,related action=accept
add chain=input connection-state=invalid protocol=!gre action=drop
add chain=input protocol=icmp action=accept
add chain=input protocol=tcp in-interface=ether1 src-address-list=mgmt-ips action=accept
add chain=input action=drop
add chain=forward connection-state=established,related action=accept
add chain=forward connection-state=invalid action=drop
add chain=forward action=drop
Only after setting up this, you can connect the server to the internet. No idea how you manage the proxmox remotely, hopefully it only listens at SSH and HTTPS and the password is not 123?
thank you very much for the rules.
I certainly want to set this up, but I still have a question mark before I completely reinstall the router.
I have now created 2 rules at nat to open the ports of the proxmox https web interface on 1 external ip address.
I have 2 external ip addresses that I can use.
if you also want to give me an example rule how I can ensure that traffic coming in on interface ether1 intended for external ip address 111.111.111.111 can forward port 123 to 192.168.200.2 that would be very nice.
I also had a somewhat stronger password than 1234 and I also use a different password everywhere.
I don’t have much experience running bare metal in public DCs so I have no idea about the network topology. How is the management interface of the Proxmox connected to the internet, if it is? Where did you create those rules, on the CHR or in some firewall provided by the datacenter?
/ip firewall nat add chain=dstnat in-interface=ether1 dst-address=111.111.111.111 protocol=udp dst-port=123 action=dst-nat to-addresses=192.168.200.2
But additionally, you have to add a permissive rule to the forward chain just before the final “drop the rest” one, something like chain=forward connection-nat-state=dstnat action=accept.
thank you very much.
I’m just installing everything on new including proxmox itself.
this because I have been messing around quite a bit here and there that it seemed smarter to me to start again at the beginning, so really.
Goodday everyone. In the meantime I’ve been puzzling again and unfortunately I’m running into 2 problems.
both are dhcp related and they appear as i have followed sindy der advices from post: Sun Jan 01, 2023 8:45 pm.
However, I do want to follow his/her advice, so the question now is how do I ensure that the DHCP problems are solved.
the problems are:
ethernet1 no longer receives an ip address from the provider or there seems to be no more dhcp traffic between the provider and the router.
problem 2: the dhcp server of mikrotik routers no longer wants to hand out ip addresses on interface ether2.
That’s strange. For IP(v4), DHCP is hooked “closer to the wire” than the firewall, so neither the handling of DHCP responses of the server on ether1 nor handling of client requests on ether2 should be affected by any firewall rules. But his may have changed since the current long-term version (6.48.6), so use the following command-line command:
/ip firewall filter add chain=input protocol=udp dst-port=67,68 action=accept place-before=[find where chain=input action=drop !(connection-state~“invalid”)]
If that helps, it means something has changed between 6.48.6 and 6.49.7; if it doesn’t, something else must be wrong. In the latter case, open a command line window, make it as wide as your screen allows, run /tool sniffer quick port=67,68 in that window and see what traffic it can gather during, let’s say, 3 minutes.
Off topic - when referring to a post, it is better to add a link to it than to refer to time, as the forum displays time information in local time, so if someone reads it in a different time zone, it may be misleading. Some skins show order numbers of posts within a topic. So I usually use post #4 (press the “respond with quote” button to see how this link is added).
first of all thank you very much.
coming in it seems to work well now and only ports that I want open are open.
the port forwardings also seem to work fine and get a nice response and can also log in.
dhcp income from the provider also works fine now.
dhcp I suspect that also works, although I still have to connect / install an extra pc that wants an ip address from the dhcp server.
I do have one more probable problem.
namely everything that is on the lan side (ether2 ipranche 192.168.200.0/24) is just allowed to access the internet as it looks now.
So if someone can help me with what I need to adjust to let traffic go outside that would be great.
luckily the security works well now.
so thank you very much for that part.
In the meantime, the connections to the 44 network are also working again.
However, one problem from the very first post and what this topic actually started for has not yet been solved.
and the question still remains how can I ensure that traffic from network 192.168.200.0/24 or one LAN network is hidden so that hamnet (the 44.x network) does not see one’s local IP address, but only the address of the router.
For that, you need a src-nat rule:
/ip firewall nat add chain=srcnat out-interface=gre09 action=src-nat to-addresses=44.137.61.34
thank you very much for the response.
unfortunately has
this may not work and outgoing traffic will still be blocked.
if I do a trace to eg: 44.137.0.1 then I get a nice response from mikrotik itself but the rest just time outs.
the ip address is also not viewable via the 44 network while it works from the outside.
and via one test connection (openvpn at my home directly to the network) then it works.
So it goes straight to the router.
Post the complete configuration.
I did not understand these statements, sorry - too many "it"s. Let’s start from the configuration.
then let me start with how the configuration is now.
  • interface ether1 goes to the internet
  • interface ether2 is the local network
  • gre is the tunnel to hamnet (hamnet is the 44 network and intended for broadcasting amateurs, i will say hamnet from now on because it is a bit easier)
  • bridge is the local part of hamnet and is intended for one hamnet ip ranch from 44.137.83.64 to 79 or a /28 subnet
which ip rachne is for what
  • 192.168.100.0/24 has become the network between one provider and one microtik router.
    traffic coming in on 85.214.62.188 and on 85.214.172.52 will be forwarded to the router through this network
    -192.168.200.0/24 is the lan network.
    all servers are in this network.
  • 44.137.83.64/28 is one hamnet ip ranche.
    where 44.137.83.65 to 44.137.83.69 are reachable both via the internet and via hamnet
what do I ultimately want to have as an end goal.
  • that I can serve both to the internet and to hamnet addresses via my local network (lan).
  • that I can make port forwardings based on ip address and thus say that for example port 80 can forward external address 85.214.62.188 (192.168.100.2) to server 192.168.200.2 and port 80 to 44.137.83.65 then to 192.168.200.3 and 80 at 44.137.83.70 to 192.168.200.4
what is my configuration right now.
/ip address print detaill
 0   address=192.168.200.1/24 network=192.168.200.0 interface=ether2 actual-interface=ether2
 1   address=192.168.100.2/24 network=192.168.100.0 interface=ether1 actual-interface=ether1
 2   address=192.168.100.3/24 network=192.168.100.0 interface=ether1 actual-interface=ether1
 3   address=44.137.83.78/28 network=44.137.83.64 interface=bridge actual-interface=bridge
 4   address=44.137.61.34/30 network=44.137.61.32 interface=gre09 actual-interface=gre09
 5   address=44.137.83.65/28 network=44.137.83.64 interface=bridge actual-interface=bridge
 6   address=44.137.83.70/32 network=44.137.83.70 interface=bridge actual-interface=bridge
/ip firewall filter print detail
 0    chain=input action=accept connection-state=established,related
 1    chain=input action=drop connection-state=invalid protocol=!gre
 2    chain=input action=accept protocol=icmp
 3    chain=input action=accept protocol=tcp src-address-list=mgmnt-ips in-interface=ether1
 4    chain=input action=accept in-interface=ether2
 5    chain=input action=accept protocol=udp dst-port=67,68
 6    chain=input action=drop
 7    chain=forward action=accept connection-state=established,related
 8    chain=forward action=accept in-interface=ether2
 9    chain=forward action=drop connection-state=invalid
10    chain=forward action=drop
/ip firewall addres-list print detail
 0   list=mgmnt-ips address=192.168.200.254 creation-time=jan/07/2023 11:34:56
 1   list=mgmnt-ips address=83.82.141.67 creation-time=jan/07/2023 11:35:54
 2   list=mgmnt-ips address=89.190.141.193 creation-time=jan/07/2023 11:36:32
/ip firewall nat print detail
 0    chain=srcnat action=src-nat to-addresses=44.137.61.34 out-interface=gre09 log=no
      log-prefix=""
 1    chain=srcnat action=masquerade out-interface-list=WAN
and finally
/ip route print detail
 0 ADb  dst-address=0.0.0.0/0 pref-src=44.137.83.78 gateway=44.137.61.33
        gateway-status=44.137.61.33 reachable via  gre09 distance=20 scope=40 target-scope=10
        routing-mark=hamnet bgp-as-path="4220406100" bgp-local-pref=50 bgp-med=0
        bgp-origin=incomplete bgp-communities=44137:10000,44137:10050 received-from=gw-44-137
 1 ADb  dst-address=44.0.0.0/9 pref-src=44.137.83.78 gateway=44.137.61.33
 2 ADb  dst-address=44.128.0.0/10 pref-src=44.137.83.78 gateway=44.137.61.33
 3 ADb  dst-address=44.137.0.0/16 pref-src=44.137.83.78 gateway=44.137.61.33
 4 A S  dst-address=44.137.61.32/32 pref-src=44.137.61.34 gateway=gre09
        gateway-status=gre09 reachable distance=1 scope=10 target-scope=10 routing-mark=hamnet
 5 A S  dst-address=44.137.83.64/28 pref-src=44.137.83.78 gateway=bridge
        gateway-status=bridge reachable distance=1 scope=10 target-scope=10 routing-mark=hamnet
 6 A S  dst-address=0.0.0.0/0 gateway=192.168.100.1
        gateway-status=192.168.100.1 reachable via  ether1 distance=1 scope=30 target-scope=10
 7 ADC  dst-address=44.137.61.32/30 pref-src=44.137.61.34 gateway=gre09
        gateway-status=gre09 reachable distance=0 scope=10
 8 ADC  dst-address=44.137.83.64/28 pref-src=44.137.83.78 gateway=bridge
        gateway-status=bridge reachable distance=0 scope=10
 9 ADC  dst-address=44.137.83.70/32 pref-src=44.137.83.70 gateway=bridge
10 A S  dst-address=145.220.78.4/32 gateway=192.168.100.1
11 ADC  dst-address=192.168.100.0/24 pref-src=192.168.100.2 gateway=ether1
        gateway-status=ether1 reachable distance=0 scope=10
12 ADC  dst-address=192.168.200.0/24 pref-src=192.168.200.1 gateway=ether2
        gateway-status=ether2 reachable distance=0 scope=10
I hope I have provided enough information. if not, I’d love to hear what else you want to know
So let me rephrase it to make sure I understand the setup and goals properly.
  • all servers are in the LAN (192.168.200.0/24, ether2).
  • the addresses from the ham subnet 44.137.83.64/28 are only up on the CHR itself, and all connections arriving to these addresses will be port-forwarded to addresses from 192.169.200.0/24. I.e. the sole purpose of the interface named bridge is to bear these addresses.
  • when a server in 192.168.200.0/24 initiates a connection towards an address in hamnet (rather than responding to an incoming connection), the local side address of that connection has to be src-nated to an address from 44.137.83.64/28 so that the remote responder would know where to send the response
Is that correct?
What I have a problem with is the requirement that the addresses from the 44.137.83.65 - 44.137.83.69 range “are reachable from the internet” - you would have to advertise this subnet to the internet using BGP in order that the traffic for it would come directly via ether1. So I suppose that there are some border routers that interconnect hamnet with the rest of the internet, and the requests from clients in internet to the 44.137.83.65 - 44.137.83.69 range actually get to the CHR via these border routers and then via gre09. And to prevent non-symmetric routing, you need to make sure that responses to such requests are routed via gre09 even though the destination address is a non-hamnet one, whereas requests that came via ether1 must be responded via ether1. Is this understanding correct?
I was expecting to see the complete export of the configuration obtained using the /export file=somename hide-sensitive command, but I would have likely asked for actual routing table right next :slight_smile:
  • the addresses from the ham subnet 44.137.83.64/28 are only up on the CHR itself, and all connections arriving to these addresses will be port-forwarded to addresses from 192.169.200.0/24. I.e. the sole purpose of the interface named > bridge > is to bear these addresses.
Is that correct?
I couldn’t have said it more clearly.
so you totally understand.
What about the other parts, i.e. the access to 44.137.83.64/28 from the internet and the export of the complete configuration?
I suspect you want to know about traffic from and to the router.
therefore here are the results of different tracerts so that the exact problem will hopefully become clear.
the first tracert 2 tracert are from home to the mikrotik router.
about hamnet.
where I immediately make the joke that 44.137.83.65 can be reached both via the internet and via hamnet, but 44.137.83.70 can only be reached via hamnet.
C:\Users\peter>tracert 44.137.83.70
Tracing route to sys10.pd9enp.ampr.org [44.137.83.70]
over a maximum of 30 hops:
  1    12 ms    13 ms    12 ms  gw-vpn1.pi9noz.ampr.org [44.137.60.3]
  2    11 ms    11 ms    11 ms  gw2.pi9noz.ampr.org [44.137.60.2]
  3    22 ms    23 ms    23 ms  sys10.pd9enp.ampr.org [44.137.83.70]
Trace complete.
C:\Users\peter>tracert 44.137.83.65
Tracing route to www.pd9enp.ampr.org [44.137.83.65]
  1    12 ms    12 ms    11 ms  gw-vpn1.pi9noz.ampr.org [44.137.60.3]
  2    19 ms    11 ms    12 ms  gw2.pi9noz.ampr.org [44.137.60.2]
  3    22 ms    30 ms    31 ms  www.pd9enp.ampr.org [44.137.83.65]
the next tracert is from home via the internet to 44.137.83.65
  1     1 ms    <1 ms    <1 ms  172.16.0.1
  2     2 ms     2 ms     1 ms  192.168.179.1
  3     *        *        *     Request timed out.
  4    10 ms    12 ms    19 ms  ht-rc0001-cr102-et112-251.core.as33915.net [213.51.194.21]
  5    20 ms    13 ms    14 ms  asd-tr0021-cr101-be152-10.core.as9143.net [213.51.158.12]
  6    12 ms    13 ms    12 ms  nl-ams04a-ri3-ae51-0.core.as9143.net [213.51.64.194]
  7    13 ms    12 ms    12 ms  ae78-0.asd001b-jnx-01.surf.net [145.145.166.72]
  8    12 ms    14 ms    15 ms  netsurf-router.customer.surf.net [145.145.2.219]
  9    27 ms    13 ms    12 ms  192.12.54.242
 10    15 ms    14 ms    12 ms  gw-44-137-ext.ampr.org [145.220.78.2]
 11    15 ms    13 ms    12 ms  gw.pi9noz.ampr.org [44.137.42.1]
 12    24 ms    24 ms    23 ms  www.pd9enp.ampr.org [44.137.83.65]
now a tracert to 8.8.8.8 from the lan network of the mikrotik routers
C:\Users\Administrator>tracert 8.8.8.8
Tracing route to dns.google [8.8.8.8]
  1    <1 ms    <1 ms    <1 ms  192.168.200.1
  2    <1 ms    <1 ms    <1 ms  192.168.100.1
  3    <1 ms    <1 ms    <1 ms  vl500.dcata-b17.as6724.net [85.214.1.25]
  4    <1 ms    <1 ms    <1 ms  433.ae7.core-b1.as6724.net [85.214.0.168]
  5     1 ms    <1 ms    <1 ms  110.ae14.bb-rt1-2.h20.r22.rs.ber.de.as6724.net [85.214.2.90]
  6    <1 ms    <1 ms    <1 ms  ae-1-88.bb-a.rs.ber.de.net.ionos.com [212.227.112.110]
  7    11 ms    11 ms    11 ms  212.227.120.11
  8    11 ms    12 ms    11 ms  ae-22.bb-b.fr7.fra.de.oneandone.net [212.227.120.40]
  9    12 ms    12 ms    12 ms  212.227.112.83
 10    10 ms    10 ms    10 ms  142.251.65.73
 11    10 ms    10 ms    11 ms  142.250.226.149
 12    11 ms    10 ms    11 ms  dns.google [8.8.8.8]
now another tracert from the lan side of the mikrotik router to a hamnet ip address 44.137.80.25
C:\Users\Administrator>tracert 44.137.80.25
Tracing route to pd9enp.ampr.org [44.137.80.25]
  2     *        *        *     Request timed out.
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
  28     *        *        *     Request timed out.
  29     *        *        *     Request timed out.
  30     *        *        *     Request timed out.
and finally 2 tracerts from the mikrotik router itself.
the first is to a hamnet ip address 44.137.80.25
the 2nd is to 8.8.8.8
[admin@MikroTik] > /tool traceroute 44.137.80.25
 # ADDRESS                          LOSS SENT    LAST     AVG    BEST   WORST STD-DEV STATUS
 1 44.137.61.33                       0%   95  11.9ms    11.1    10.8    12.5     0.3
 2 44.137.60.3                        0%   94  11.3ms    11.1    10.8    11.9     0.2
 3 44.137.80.25                       0%   94  22.9ms    24.2    21.7      36     2.7
[admin@MikroTik] > /tool traceroute 8.8.8.8
 1 192.168.100.1                      0%    5   0.3ms     0.2     0.2     0.3       0
 2 85.214.1.25                        0%    5   0.4ms     4.4     0.3    20.6     8.1
 3 85.214.0.168                       0%    5   0.5ms     0.8     0.4     2.4     0.8
 4 85.214.2.90                        0%    5   0.9ms       1     0.4     2.5     0.8
 5 212.227.112.110                    0%    5   0.9ms     0.8     0.7     0.9     0.1
 6 212.227.120.11                     0%    5  10.8ms    10.9    10.8      11     0.1
 7 212.227.120.40                     0%    5  14.6ms    11.8      11    14.6     1.4
 8 212.227.112.83                     0%    5  12.5ms    12.3    12.2    12.5     0.1
 9 142.251.65.73                      0%    5  10.9ms    10.7    10.5    10.9     0.1
10 142.250.226.149                    0%    5  10.5ms    10.6    10.5    10.7     0.1
11 8.8.8.8                            0%    5  10.6ms    10.5    10.5    10.6       0
I hope it is clear what your problem is
It wasn’t immediate, but OK.
What happens is that you have configured BGP to add the routes into routing table hamnet, but you don’t assign a corresponding routing-mark to the traffic anywhere (maybe you do but as you have only posted what you deem relevant rather than posting the complete export, I strongly suspect you indeed don’t). So gre09 is only ever used by incoming traffic from the hamnet, whereas all the outgoing traffic, including one to hamnet destiniations, is routed via ether1/192.168.100.1. Hence the src-nat rule I’ve suggested never matches the connections initiated by hosts in 192.168.200.0/24 towards hamnet destinations. And since they get src-nated to the internet address instead, the response to that internet address from the remote hamnet host being pinged probably gets blocked by some firewall.
Your traceroute shows that the non-symmetric routing doesn’t matter (no firewalls on the uncommon network paths), the question is whether you don’t mind that you send the traffic to hamnet destinations via internet rather than via the tunnel.
Given that although (or maybe because?) Dutch and English are really close, the translation by Google is far from perfect. So the joke got lost in translation. I haven’t even noticed that there is a difference in behaviour between .65 and .70.
I do have quite a lot of problems, but your traceroutes haven’t helped with any of them :smiley:
