Hide ISP Provider
hi, i want know to hide ISP provider name from last mile customers during Speed test websites.
Im already using squid proxy in my server.
Here is the example speed test:
I want hide “bharathi Broadband” from last mile customers
help me
Thanks in advance
I think you can’t do it, because every Public IP refer to registered an ISP. So when you connect to Internet, You are using Public IP :slight_smile:
is it is possible by using any proxy server??
Not practically.
One way is to use VPN. For that you’ll have to find “a friendlier ISP” who you are willing to show on Speedtest page and make a VPN tunnel to their network.
Ask your provider to change their IP assignment in APNIC (i.e. if they assigned you a block of IP’s). If the connection you have is a DSL connection that is not possible since the IP you have is part of a much bigger pool of IP addresses and is not possible to change the listings in APNIC.
Search IP at the following website and see the results:
http://wq.apnic.net/apnic-bin/whois.pl
Sotiris
