hello everyone , is there any rule in Mt3.13 to hide my real ip from customers?
ex: if anyone type www.ip-adress.com can see my real ip and make attack on it.
so i need to hide my real ip to protect myself.
best regards.
No.
Protect router and your network with some filter rules…
Look at Mikrotik Wiki…
http://wiki.mikrotik.com/wiki/Firewall
the only way to hide your real IP is to disable uplink interface
VPN is the best choice for hiding your IP address, you can install the software and proceed your network. I had also installed hide IP software from VPN after that i refer the website http://www.IP-Details.com/ and identified my IP address change. Best wishes.
Hi ,
Secure your router with firewall rules my friend , hiding IP address or establishing VPN is not a real solution
Good luck
Unfortunately this is how networks work. IP has to be known otherwise you cannot get the packets. You can use tunnels, proxies or whatever but your ip address will be everytime known to at least someone. If you are afraid, secure yourself. If you are paranoic, cut off the connection to the Internet.
