High Availability for User Manager v7 and Dynamic Connection Limiting per User
Hi everyone,
I am designing a network infrastructure using MikroTik (ROS v7.x) and I’m looking for the "Best Practice" to implement two specific requirements:
1. Redundancy for User Manager (HA): I want to deploy two User Manager instances. The second instance should act as a backup.
  • Is there a native way to synchronize the database between two User Manager instances in ROS v7?
  • In case the primary User Manager fails, how can I ensure the NAS (Network Access Server) seamlessly switches to the secondary one without dropping active sessions? Should I use VRRP for a Virtual IP or define multiple RADIUS servers in the /user-manager/router configuration?
2. Source Public IP Limiting (Anti-Abuse): I need a mechanism to restrict each user to a maximum of 3 concurrent Source Public IP addresses.
  • If a user attempts to connect from a 4th Public IP, the system should automatically drop/disconnect one of the existing active sessions (e.g., the oldest one) to allow the new one, or simply block the 4th IP.
  • Can this be handled directly within User Manager attributes (Session-Timeout) or do I need a custom script combined with Firewall Filter/Raw?
Current Setup:
  • Hardware: Router OS x86
  • ROS Version: 7.x
  • Architecture: User Manager as Radius Server, multiple NAS devices.
Looking forward to your professional advice. Thanks! :heart_eyes:
