Dear All,
I’m a newbie with Mikrotik Product, I get my first a month ago and the second yesterday ![]()
With the first one :
I setup it as PPPOE server with usermanager behind a BGP and it works .
Ether1 : WAN
Ether2: LAN MGT
Etther3 : connected to my dslam + PPPOE Server
Now with the second I would to configure it as it act as a slave of the other one in case a failure.
I decided to try VRRP so I created three VRRP with the same VRID for WAN + LAN interface I use but if I shutdown my Master Mikrotik entirely I can access to the SLAVE by the WAN or LAN but my pppoe client are disconnected.
So can you advise me how can I set it up to get high avialabilty working correctly for pppoe client ?
Is it possible to sync usermanager together as now when I created a user I do it on both ?
Is there also a way to synchronised the Mikrotik configuration to the slave as if I make a modification on the Master it is replicated on the slave automaticallly ?
If you need more details on my configuration just tell me what you need
Thanks in advance
Best Regards
