We also tried Dude Beta 3.04.
CPU usage on monitored switches or routers has increased by 6 % immediately after starting monitoring. We monitor only ping service and operational status from one or two interfaces per device. After downgrading to Dude 2.2 the load on devices is normal again.
The new Beta 3.05 has the same bug.
Any idea what causes this permanent high load?
Note that after server startup dude server uses more bandwidth than during
normal operation (after some minutes). In version 3 additional bandwidth is
used for populating mac-mapping table. You can try to increase the refresh
interval (default 5 minutes) in ‘Server Configuration’ → Misc tab → ‘Mac
Mapping Refresh Interval’. Then your traffic should be back to normal.
Please report back if that helps or not. Ideally provide us with capture file
and/or your configuration export to help us look for potential problems.
