Since last update I have problems that my cpu after 24h goes from 10% to 60% and higher. I used snmp and after I saw someone have same problems found here on forum I disabled it. That didn’t help me, I turned off snmp yesterday and again cpu usage is like 70%. Most of CPU takes management profile everything else is in most cases maximum 10%. My graphs shows me that cpu every hour goes for few % up.
I sent email to support with supout.rif file immediately after I activate kid control my cpu goes from 3 to 40%. I will inform you if support contacts me back.
Hello, it seems that is problem with firmware 6.43.2. I have internet connection from my ISP 300Mbps down/20Mbps up. When i tested my internet speed link via speedtest.net i was not unable over 150Mbps and CPU usage raised over 60%. Today i replaced my router with new model and problem solved. I think that this problem is “model specific”.
Cpu load > 60% on RB951G-2HnD and unable get over 160Mbps.
Cpu load < 30% on RouterBOARD 962UiGS-5HacT2HnT and max speed over 300Mbps.
I can confirm that also on my 951 also speedtest 120/10 with packet mark and queue activate cpu load almost 100%
2 parent tree for download and upload and 10 child / 5 for each, I used this for ping and game priority
14 packet / connection marks
Found documentation about my device and think that should not cause 90% cpu load.
At the end I had to turn off everything because I though I didn’t configure it ok, seems I m not alone…
