during past few hours I have high CPU load by “www” process on my RB2011UiAS router. Total CPU load is close to 100%. I disabled both IP services - www and www-ssl, upgraded to the latest RouterOS release but nothing have changed.
Thank you for reply. Nothing special in the log file. It still have high load by www process which I wouldn’t expect to see at all because both ip service - www and www-ssl - are disabled. But it is not too high now.
Are you using ssl hotspot? If so its just the cpu load in preparing the encryption. The only way to solve is to increase cpu with better hardware or separate the wireless and hotspt with a different router. For example you can use like rb450g or a wired router for the hotspot service and a separate wireless ap.
