Do you use dynamic queues?
Check and be sure that they are correctly configured.
Chech the rate limit in the usermanager.
If things continues that way, backup your userman database and install a fresh copy of the ROS preferrably a higher version this time.
Then load your usermanager backup file into the database.
If things does not change then U may need to post your configurations
