I’m migrating from a Cisco setup that is currently working to a Mikrotik CCR1036-12G-4S. We got this router because it was the most expensive, so we thought it would work fine. My problem is that I added 6 GRE tunnels from remote datacenter and I am routing IP ranges through these tunnels. I’m not talking about 1 or 2 /27s…some tunnels have 15 /24s through them. All-in-all, there are about 9,000 IP addresses that are being tunneled. The IPs are bound to internal servers via their public IP and traffic goes out through the Mikrotik on the default gateway. I can run with 2 or 3 GRE tunnels with 5-6 /24s just fine. But when I enable all the GRE tunnels, I get lost packets, the ping times shoot up to 4-7 seconds and the router boots my connection.
I ran /tools profile and saw that whenever this happened, the “networking” process was consuming 40%-60% CPU (across all CPUs). No other processes are consuming anywhere near that CPU percentage.
I thought that maybe the problem was that I had exceeded some internal routing table limit (like 4096, which seems common for an internal routing table of 4k). Then I thought it was bandwidth, but we were only sending out like 5-10 Mbps. Could it be something with routing the packets out? I enabled proxy-arp on the WAN interface (ether8) to handle the outgoing traffic from the server.
Can this router board even support what I am doing? Is there a hardware switch I can add to the router board or even buy a different one?
Before I spend hours trying to debug this ghost issue, I’d like to know if I am just attempting to do too much on this router.
Here are my versions and such. I can send the supout.rif if anyone needs it.
[admin@MikroTik] > system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 routeros-tile 6.26
1 system 6.26
2 X wireless-fp 6.26
3 X ipv6 6.26
4 X wireless 6.26
5 hotspot 6.26
6 dhcp 6.26
7 mpls 6.26
8 routing 6.26
9 ppp 6.26
10 security 6.26
11 advanced-tools 6.26
[admin@MikroTik] > /tool profile
NAME CPU USAGE
www all 0%
snmp all 0%
console all 0%
graphing all 0%
ssh all 0%
dns all 0%
firewall all 0.2%
networking all 34.5%
tftp all 0%
gre all 0%
logging all 0%
management all 0%
routing all 0%
idle all 64.7%
profiling all 0.2%
bridging all 0%
unclassified all 0%
[admin@MikroTik] > /system routerboard print
routerboard: yes
model: CCR1036-8G-2S+
serial-number: 529E04D0F21E
current-firmware: 3.22
upgrade-firmware: 3.22
[admin@MikroTik] > interface gre print
0 name="Tunnel249" mtu=1476
actual-mtu=1476 local-address=173.232.117.249
remote-address=108.178.8.34 dscp=inherit clamp-tcp-mss=no
dont-fragment=no
1 name="Tunnel250" mtu=1476 actual-mtu=1476
local-address=173.232.117.250 remote-address=173.44.243.244
dscp=inherit clamp-tcp-mss=no dont-fragment=no
2 name="Tunnel251" mtu=1476 actual-mtu=1476
local-address=173.232.117.251 remote-address=37.228.130.25 dscp=inherit
3 name="Tunnel252" mtu=1476
actual-mtu=1476 local-address=173.232.117.252 remote-address=5.83.140.3
4 name="Tunnel253" mtu=1476 actual-mtu=1476
local-address=173.232.117.253 remote-address=213.21.225.14 dscp=inherit
5 X name="Tunnel254" mtu=1476
actual-mtu=1476 local-address=173.232.117.254
remote-address=146.185.242.2 dscp=inherit clamp-tcp-mss=no
dont-fragment=no
Here is a sample of the pings as the CPU creeps up then backs back down (normal ping times are 46 ms):
64 bytes from 23.90.60.146: icmp_seq=3947 ttl=52 time=46.724 ms
64 bytes from 23.90.60.146: icmp_seq=3948 ttl=52 time=47.792 ms
64 bytes from 23.90.60.146: icmp_seq=3949 ttl=52 time=46.921 ms
64 bytes from 23.90.60.146: icmp_seq=3950 ttl=52 time=45.765 ms
64 bytes from 23.90.60.146: icmp_seq=3951 ttl=52 time=47.210 ms
64 bytes from 23.90.60.146: icmp_seq=3952 ttl=52 time=49.981 ms
64 bytes from 23.90.60.146: icmp_seq=3954 ttl=52 time=690.835 ms
64 bytes from 23.90.60.146: icmp_seq=3953 ttl=52 time=2562.783 ms
64 bytes from 23.90.60.146: icmp_seq=3955 ttl=52 time=1549.045 ms
64 bytes from 23.90.60.146: icmp_seq=3957 ttl=52 time=510.710 ms
64 bytes from 23.90.60.146: icmp_seq=3956 ttl=52 time=1995.245 ms
64 bytes from 23.90.60.146: icmp_seq=3958 ttl=52 time=706.535 ms
64 bytes from 23.90.60.146: icmp_seq=3959 ttl=52 time=748.073 ms
64 bytes from 23.90.60.146: icmp_seq=3960 ttl=52 time=419.606 ms
64 bytes from 23.90.60.146: icmp_seq=3961 ttl=52 time=466.671 ms
64 bytes from 23.90.60.146: icmp_seq=3962 ttl=52 time=1102.575 ms
Request timeout for icmp_seq 69500
Request timeout for icmp_seq 69501
64 bytes from 23.90.60.146: icmp_seq=3966 ttl=52 time=671.800 ms
Request timeout for icmp_seq 69503
64 bytes from 23.90.60.146: icmp_seq=3967 ttl=52 time=1711.755 ms
Request timeout for icmp_seq 69505
64 bytes from 23.90.60.146: icmp_seq=3969 ttl=52 time=1067.613 ms
64 bytes from 23.90.60.146: icmp_seq=3968 ttl=52 time=2260.470 ms
Request timeout for icmp_seq 69508
64 bytes from 23.90.60.146: icmp_seq=3972 ttl=52 time=1160.803 ms
64 bytes from 23.90.60.146: icmp_seq=3971 ttl=52 time=2760.430 ms
64 bytes from 23.90.60.146: icmp_seq=3974 ttl=52 time=801.476 ms
64 bytes from 23.90.60.146: icmp_seq=3975 ttl=52 time=1709.493 ms
64 bytes from 23.90.60.146: icmp_seq=3977 ttl=52 time=960.410 ms
64 bytes from 23.90.60.146: icmp_seq=3976 ttl=52 time=2642.457 ms
Request timeout for icmp_seq 69515
64 bytes from 23.90.60.146: icmp_seq=3979 ttl=52 time=1164.111 ms
64 bytes from 23.90.60.146: icmp_seq=3980 ttl=52 time=722.044 ms
64 bytes from 23.90.60.146: icmp_seq=3981 ttl=52 time=239.143 ms
64 bytes from 23.90.60.146: icmp_seq=3978 ttl=52 time=3446.835 ms
64 bytes from 23.90.60.146: icmp_seq=3982 ttl=52 time=802.285 ms
64 bytes from 23.90.60.146: icmp_seq=3983 ttl=52 time=335.949 ms
64 bytes from 23.90.60.146: icmp_seq=3984 ttl=52 time=359.406 ms
64 bytes from 23.90.60.146: icmp_seq=3985 ttl=52 time=44.808 ms
64 bytes from 23.90.60.146: icmp_seq=3986 ttl=52 time=303.564 ms
64 bytes from 23.90.60.146: icmp_seq=3987 ttl=52 time=221.595 ms
64 bytes from 23.90.60.146: icmp_seq=3988 ttl=52 time=185.180 ms
64 bytes from 23.90.60.146: icmp_seq=3989 ttl=52 time=1464.084 ms
64 bytes from 23.90.60.146: icmp_seq=3990 ttl=52 time=464.706 ms
64 bytes from 23.90.60.146: icmp_seq=3991 ttl=52 time=48.219 ms
64 bytes from 23.90.60.146: icmp_seq=3992 ttl=52 time=973.814 ms
64 bytes from 23.90.60.146: icmp_seq=3993 ttl=52 time=92.268 ms
64 bytes from 23.90.60.146: icmp_seq=3994 ttl=52 time=44.831 ms
64 bytes from 23.90.60.146: icmp_seq=3995 ttl=52 time=44.633 ms
64 bytes from 23.90.60.146: icmp_seq=3996 ttl=52 time=425.471 ms
64 bytes from 23.90.60.146: icmp_seq=3997 ttl=52 time=257.915 ms
64 bytes from 23.90.60.146: icmp_seq=3998 ttl=52 time=48.591 ms
64 bytes from 23.90.60.146: icmp_seq=3999 ttl=52 time=47.437 ms
64 bytes from 23.90.60.146: icmp_seq=4000 ttl=52 time=44.998 ms
64 bytes from 23.90.60.146: icmp_seq=4001 ttl=52 time=45.254 ms
64 bytes from 23.90.60.146: icmp_seq=4002 ttl=52 time=46.293 ms
64 bytes from 23.90.60.146: icmp_seq=4003 ttl=52 time=45.440 ms
64 bytes from 23.90.60.146: icmp_seq=4004 ttl=52 time=47.513 ms
64 bytes from 23.90.60.146: icmp_seq=4005 ttl=52 time=45.615 ms
64 bytes from 23.90.60.146: icmp_seq=4006 ttl=52 time=44.836 ms
64 bytes from 23.90.60.146: icmp_seq=4007 ttl=52 time=45.666 ms
