hi everyone,
how can i solve this problem, i m getting high latency, when i ping or browse.
free image uploading
here it is my configuration
oct/13/2016 11:38:41 by RouterOS 6.37.1
software id = 5XN3-0B5F
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether5 ] master-port=ether2
set [ find default-name=ether6 ] master-port=ether2
set [ find default-name=ether7 ] master-port=ether2
set [ find default-name=ether8 ] master-port=ether2
set [ find default-name=sfp1 ] auto-negotiation=no master-port=ether2
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface pptp-client
add connect-to=96.228.33.58 mrru=1600 name=pptp-out1 password=****** user=
gabak
/ip neighbor discovery
set ether1 discover=no
/interface vlan
add interface=ether2 name=vlan11-bearer vlan-id=11
add interface=ether2 name=vlan12-external vlan-id=12
add interface=ether2 name=vlan101-pdn vlan-id=101
add interface=ether2 name=vlan102 vlan-id=102
add interface=ether2 name=vlan201-layer2 vlan-id=201
add name=dhcp_pool1 ranges=192.168.10.22-192.168.10.222
add name=dhcp_pool2 ranges=192.168.0.2-192.168.0.254
add name=dhcp_pool3 ranges=192.168.101.2-192.168.101.254
add name=dhcp_pool4 ranges=192.168.101.2-192.168.101.254
add name=dhcp_pool5 ranges=192.168.201.2-192.168.201.254
add name=dhcp_pool6 ranges=10.10.10.2-10.10.10.254
add name=vpn ranges=10.0.0.6-10.0.0.66
add address-pool=dhcp_pool1 disabled=no interface=ether2 name=dhcp1
add address-pool=dhcp_pool2 disabled=no interface=vlan12-external name=dhcp2
add address-pool=dhcp_pool3 disabled=no interface=vlan11-bearer name=dhcp3
add address-pool=dhcp_pool4 disabled=no interface=vlan101-pdn name=dhcp4
relay=192.168.101.2
add address-pool=dhcp_pool5 disabled=no interface=vlan201-layer2 name=dhcp5
add address-pool=dhcp_pool6 disabled=no interface=vlan102 name=dhcp6
/ppp profile
add local-address=vpn name=vpn remote-address=vpn
/tool user-manager customer
set admin access=
own-routers,own-users,own-profiles,own-limits,config-payment-gw
/interface pptp-server server
set enabled=yes
add address=192.168.10.1/24 interface=ether2 network=192.168.10.0
add address=192.168.1.254/24 interface=vlan11-bearer network=192.168.1.0
add address=192.168.0.254/24 interface=vlan12-external network=192.168.0.0
add address=192.168.201.254/24 interface=vlan201-layer2 network=192.168.201.0
add address=192.168.101.254/24 interface=vlan101-pdn network=192.168.101.0
add address=10.10.10.254/24 interface=vlan102 network=10.10.10.0
add address=174.142.135.242/28 interface=ether1 network=174.142.135.240
add address=10.10.10.0/24 gateway=10.10.10.1
add address=192.168.0.0/24 gateway=192.168.0.1
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.101.0/24 gateway=192.168.101.254
add address=192.168.201.0/24 dns-server=8.8.8.8,208.67.222.222 gateway=
192.168.201.254
set allow-remote-requests=yes servers=209.18.46.62,8.8.8.8,209.18.47.61
add action=accept chain=input disabled=yes dst-port=1723 protocol=tcp
add action=accept chain=forward disabled=yes protocol=gre
add action=drop chain=forward disabled=yes dst-port=53 out-interface=!ether1
protocol=udp
add action=drop chain=input disabled=yes dst-port=53 in-interface=ether1
protocol=udp
protocol=tcp
protocol=udp
protocol=tcp
add action=fasttrack-connection chain=forward connection-state=
established,related disabled=yes
add distance=1 gateway=174.142.135.241
/ip service
set telnet disabled=yes
set ssh disabled=yes
/lcd
set time-interval=daily
/lcd interface pages
set 0 interfaces=wlan1
/ppp secret
add name=123 password=13 profile=vpn
add name=Telrad password=LteAmin! profile=vpn
add name=mark password=mrk123 profile=vpn service=pptp
add name=david password=davi3 profile=vpn
/system clock
set time-zone-name=America/New_York
/system identity
set name=Telrad-TIK
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set vlan201-layer2 disabled=yes display-time=5s
set vlan102 disabled=yes display-time=5s
set vlan101-pdn disabled=yes display-time=5s
set vlan12-external disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
set ether6 disabled=yes display-time=5s
set ether7 disabled=yes display-time=5s
set ether8 disabled=yes display-time=5s
set sfp1 disabled=yes display-time=5s
set vlan11-bearer disabled=yes display-time=5s
set pptp-out1 disabled=yes display-time=5s
/system routerboard settings
set protected-routerboot=disabled
/tool user-manager database
set db-path=user-manager
