I had an old HP computer that had a pentium ~233 processor in it with 128Mb memory. I was running two four port ethernet cards on the box. The power supply finally died on it and I decided to upgrade the hardware since this router is a core router. On the old HP, I was running around 10 percent CPU usage on average.
Because this was an emergency failure, I went to a local box store and bought an off the shelf e-machine that has an AMD 1.8Ghz processor and 256Mb memory. I took the hard drive out of the HP and put it in the emachine. It booted up fine. The only thing it didnt do was recognize the on-board ethernet port. This wasn’t a problem because I didn’t need it with the other 8 ports I had available.
However, now the CPU stays > 80 percent most of the time and will sit at 100 percent for a great portion of time. This seems to be service affecting because it slows down everyone on the router.
Why would this hardware change make the CPU run so much harder?
