High CPU usage of Winbox on RB2011
I have purchased an RB2011 and upgraded RouterOS to v6.10 yesterday. It came with v6.5.
I am observing high CPU usage when Winbox is open and the router is practically idle (6 interfaces are up, no traffic). CPU load is 60-70 percent. When Winbox is closed, the Touchscreen reports 8-10 percent load.
http://dl.dropboxusercontent.com/u/61700377/screens/winbox-cpu-usage.png
I am reading here that higher CPU usage is expected. However, opening Winbox on RB532 with even more windows twice, over both IP and MAC, causes about 5 to 10% CPU load there.
as i’m a linux guy i’m not using winbox at all, am i the only who just use ssh and web?
but have you checked what is eating the cpu cycles with the profile tool?
Open Tool->Profile to check what exactly eats the CPU.
I did not know about the Profile tool.
The category is unclassified. Now that I can look closer, if I create a 100 MBit connection, the percentage under ‘unclassified’ goes down, allowing the data transfer to take place normally. Then it rises again.
I have solved this problem. The CPU usage was caused by an open System → RouterBoard window, which opened by default after upgrade and reboot, and was hidden behind other windows. After closing it, CPU load is at 10% now.
I’m wondering why this can cause so much cpu usage. mikrotik? is this maybe a bug?
Any recomendation when the usage comes from DNS??? It jump all the time to 80% just on DNS
Because of your bad firewall… Search for dns amplification attack and do not forget to drop all unwanted connections from wan port…
