Hello everyone,
I am facing an issue with one of the cores of my Mikrotik router which is running at 100% CPU usage while the other cores are free. Even when I use fasttrack, it alleviates the problem but the CPU usage still remains elevated.
This router is being used as a PPPoE concentrator with an average of 600 sessions and a traffic rate of 1.4Gbit/s. It is virtualized on a KVM server with a host machine of 48x Intel(R) Xeon(R) CPU E5-2670 v3 @ 2.30GHz and 47GiB RAM. The Mikrotik virtual machine is allocated 10GiB RAM and 32 cores.
Despite having a high-end configuration, the CPU usage remains high only on one core. I have attached some screenshots that might help in identifying the issue.
Can anyone suggest any solution to this problem? Any help would be greatly appreciated.
Thank you.
