high CPU utilization RB2011L (100%CPU)
Network Setup:
7 DSL lines with 8_MB speed Each
PCC Load Balancing runing on Router Board RB2011L Mikrotik OS ver 5.16 and also check on router Board RB2011UAS-2Hnd Mikrotik Os ver. 6.1
Problem is Cpu is on 100% at peak times 40 to 30 Traffic going
here is test
tool profile
NAME CPU USAGE
ppp all 0%
pppoe all 2%
ppp all 4%
ethernet all 7.5%
console all 0.5%
dns all 20%
firewall all 40%
winbox all 0%
management all 1.5%
profiling all 1%
queuing all 18.5%
routing all 2%
unclassified all 3%is that any way to make it better ?
Experts waiting for your attention ?
No one can help you without more details. Export you config. Also consider update to version 6.xx because some thing are more optimized in 6.xx.
Dns and firewalling. Looks like some attack that is not handled correctly. Maybe…
instead of dropping packets, try tarpit. It does the same thing but with less CPU.
Already tested on 6.1 issue is same
here is configuration
/ip firewall mangle
add action=mark-connection chain=input in-interface=pppoe-out1 new-connection-mark=wan1_conn
add action=mark-connection chain=input in-interface=pppoe-out2 new-connection-mark=wan2_conn
add action=mark-connection chain=input in-interface=pppoe-out3 new-connection-mark=wan3_conn
add action=mark-connection chain=input in-interface=pppoe-out4 new-connection-mark=wan4_conn
add action=mark-connection chain=input in-interface=pppoe-out5 new-connection-mark=wan5_conn
add action=mark-connection chain=input in-interface=pppoe-out6 new-connection-mark=wan6_conn
add action=mark-connection chain=input in-interface=pppoe-out7 new-connection-mark=wan7_conn
add action=mark-routing chain=output connection-mark=wan1_conn new-routing-mark=to_wan1
add action=mark-routing chain=output connection-mark=wan2_conn new-routing-mark=to_wan2
add action=mark-routing chain=output connection-mark=wan3_conn new-routing-mark=to_wan3
add action=mark-routing chain=output connection-mark=wan4_conn new-routing-mark=to_wan4
add action=mark-routing chain=output connection-mark=wan5_conn new-routing-mark=to_wan5
add action=mark-routing chain=output connection-mark=wan6_conn new-routing-mark=to_wan6
add action=mark-routing chain=output connection-mark=wan7_conn new-routing-mark=to_wan7
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=wan1_conn \
    per-connection-classifier=both-addresses-and-ports:7/0
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=wan2_conn \
    per-connection-classifier=both-addresses-and-ports:7/1
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=wan3_conn \
    per-connection-classifier=both-addresses-and-ports:7/2
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=wan4_conn \
    per-connection-classifier=both-addresses-and-ports:7/3
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=wan5_conn \
    per-connection-classifier=both-addresses-and-ports:7/4
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=wan6_conn \
    per-connection-classifier=both-addresses-and-ports:7/5
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=wan7_conn \
    per-connection-classifier=both-addresses-and-ports:7/6
add action=mark-routing chain=prerouting connection-mark=wan1_conn in-interface=Local new-routing-mark=to_wan1
add action=mark-routing chain=prerouting connection-mark=wan2_conn in-interface=Local new-routing-mark=to_wan2
add action=mark-routing chain=prerouting connection-mark=wan3_conn in-interface=Local new-routing-mark=to_wan3
add action=mark-routing chain=prerouting connection-mark=wan4_conn in-interface=Local new-routing-mark=to_wan4
add action=mark-routing chain=prerouting connection-mark=wan5_conn in-interface=Local new-routing-mark=to_wan5
add action=mark-routing chain=prerouting connection-mark=wan6_conn in-interface=Local new-routing-mark=to_wan6
add action=mark-routing chain=prerouting connection-mark=wan7_conn in-interface=Local new-routing-mark=to_wan7
Try some newer version. 6.1 is really old…
