high cpu utlization when eoip connection lost :s any ideas ?
hi, im having a strange problem here! consider the following diagram. I have 2 eoip tunells on main router (rb333), central hotspot running on a 333 and bridged to other 2 locations via eoip, when eoip tunnels are active eveything works like solid! 333 have %40 %55 cpu usage, BUT if any of the eoip tunnel connections drop , the cpu of 333 jumps up to the %100!! and i cannot access the board! all i have to do is to wait untill the tunnelling connections become available and everything become normal! any ideas how to over come this ?
Maybe because EoIP drops cos cpu utilization goes to 100%
(call me btw lost your number :slight_smile: )
no, eveything work perfect even when almost 4mbps traffic passes thru tunell, but whenever one of the tunelles lost connection everything goes crazy :s, i was suspicios if these happen all bcoz of version diffrence since 133 runs 2.9.51 and 433 runs 3.14 , but thats not the right place to look for a solution:=)
its bit late :stuck_out_tongue: so i ll give you a ring 2morrow =)
can someone at least tell me im the one all over the world who has this problem :confused:
do you have some kind of routing loop or routing calculation that happens when that drops ?
nope, i can post the config if needed.
