Hi all, I have to set a P2P wireless link in a high density scenario.
There are no free channels.
It is possible to make a link between to dynadish in nv2 or nstream (or netbox)
Any suggestion will be grateful.
Thanks in advance.
In high density you need spectral-scan. So all routerboard with AC are out of play.
You need dual-chain parabolic antenna + https://mikrotik.com/product/RB911G-5HPnD
Thanks Honzam!!
If its really nasty Cambium might be the only way to maintain a decent link. Otherwise shield the best you can and try to find a clean channel and hope nobody changes their channels.
