I have wireless link between routerboard600 & rb433. Sometimes latency grows up to 1000-2000ms. Sometimes a lost of packets is very large, but signal-noise is good. Why does it happen?
Config rb600:
[admin@MikroTik] > int wire pr
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:2B:99:B9 arp=enabled interface-type=Atheros AR5413 mode=station-wds
ssid="123" frequency=5825 band=5ghz scan-list=default antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=bridge1
wds-ignore-ssid=yes default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
[admin@MikroTik] > int br pr
0 R name="bridge1" mtu=1500 arp=enabled mac-address=00:0C:42:28:DE:7B protocol-mode=none priority=0x8000 auto-mac=yes
admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
[admin@MikroTik] > int wire registration-table pr
# INTERFACE RADIO-NAME MAC-ADDRESS AP SIGNAL-STRENGTH TX-RATE UPTIME
0 wlan1 000C422B99CB 00:0C:42:2B:99:CB yes -56dBm@6Mbps 54Mbps 1h16m38s
Config rb433:
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:2B:99:CB arp=enabled interface-type=Atheros AR5413 mode=bridge ssid="123"
wds-ignore-ssid=no default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=yes security-profile=default compression=no
0 R name="bridge1" mtu=1500 arp=enabled mac-address=00:0C:42:36:A3:28 protocol-mode=none priority=0x8000 auto-mac=yes
0 wlan1 000C422B99B9 00:0C:42:2B:99:B9 no -59dBm@48Mbps 54Mbps 1h19m26s
What kind of information you needs to be able at helping me?
