high-level structure to build an efficient, recommendations?
Hi MKs,
I would like to tidy up /restructure my firewall.
Instead of asking detailed questions, I would like to get opinions on how to structure it efficiently so that the CPU is spared as much as possible.
  1. general protection for the router, against e.g. DsS/DDoS attacks, so RAW
  2. Accept everything that is already running, or send it to FastTrack:
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
  2. ```text
add action=accept chain=forward comment="default configuration" connection-state=established,related,untracked
add action=accept chain=input comment=“default configuration” connection-state=established,related,untracked
(maybe move this to router-access?)
3. website filter, if desired
4. allow new browser connections and email:
1. ```text
add action=accept chain=forward in-interface=VLANsWithWANAccees-List out-interface=WAN port=(email ports and 80, 443)
  1. drop false connections:
6. Protect router
7. Filter router access
1. ```text
…chain=input …
8. Protect LAN
1. Restrict access between VLANs (192.168.0.0/16 are all VLANs)
```text
add action=drop chain=forward dst-address=192.168.0.0/16 src-address=192.168.0.0/16
  1. not NAT’d traffic → drop
  2. drop rest
Forget “3” , there is no such thing as a webfilter in RouterOS that can be done efficiently to save CPU-cycles.
Venturing in any of this higher-level OSI-layer processing will have huge CPU-impact dwarfing your other rules…
Option “4” ? There is much much more then only browser & mail … only allowing these will break a lot…what is your environment ? Home-user ? Office/Enterprise ? Service-Provider ?
wow that was quick :smiley:
but if someone wants to block youtube for his/her kids if you don’t redirect to e.g. PiHole?
forgot to add
somewhere between 4 and the end. Depending what checks you may want to add on normal web traffic from LANtoWAN
There is some ways to probably block Youtube completely, but I’ve never experimented with them if they are 100% working in 2022
With thing like “private DNS” (DNS-over-HTTPS etc) , usage of QUIC-protocol etc things are getting more complex. You need to block & intercept all of that stuff or will find some ways to “sneek through”
A rules like this seems to work over here :
add action=reject chain=blocklist comment=“block youtube” protocol=tcp reject-with=icmp-network-unreachable tls-host=youtube
I saw it too and the answer on that below is not 100% usable continue discussion could be endless as it seems not to be that trivial, even for Pi-hole (#1&#2) or openWRT (#1&#2).
I would like to keep a high-level discussion at least until the structure is agreed :slightly_smiling_face:. I rephrased the topic’s title, as the wording was not that well.
