I’ve got a RB1200 router showing load from 60 to 100%. IT manages a fairly big amount of traffic (35 Mbps on average, 25kpps average, with peaks of 70 Mbps and 40kpps) but nothing over the specs.
There are a couple of singular things in this router:
it manages several VLANs in one interface
there is a VoIP system with avg 250 concurrent calls on average behind the router, connected to one VLAN (the load started after switching on this system)
FW version is 5.2 (I know I have to upgrade, but planning the downtime is not easy).
Any idea on the reason behind this high load? Suggestions?
unclassified means you have a really old RouterOS version, upgrade to v5.16
in old versions, some processes didn’t have names yet. they were all called “unclassified”
I don’t know if it was a coincidence, the effect of a reboot or the firmware upgrade. I’ve upgraded to 5.16 and after the reboot the load is much lighter (20-30%, with peaks going up to 60%).
The output of /tool profile shows (right now is our valley hour, but load is significantly lower than yesterday at the same hour):
[admin@datacenter] > /tool profile
NAME CPU USAGE
www all 0%
console all 0.5%
firewall all 7.5%
management all 0%
idle all 83%
queuing all 9%
Thanks for the tip! It took 75 seconds to reboot and upgrade, but they were worth it!
would you please put a screen shot of your tools/profile in your pick time,
i bought a 1200 today but i afraid to put it in action , my config is 30 Vlan in first 5 interfaces ,
Queueing - 1000 Full firewalling rules , NAT , PPTP , two IP sec tunnel , multihome BGP 3 neighbors and i think i have 2000 TPS ,
waiting for Cloud core 1036, any one has any idea or suggestion that this device can handle this amount of traffic ?
My config is much simpler, but was handling > 25k pps. I’ve switched to a RB1100 AHx2 and now the performance impact is much lower.
NAME CPU USAGE
snmp all 0%
ethernet all 4.2%
console all 0%
firewall all 14.7%
winbox all 0%
management all 0.5%
idle all 74.2%
profiling all 0%
queuing all 6.2%
unclassified all 0%
You can see the graphs below. In the monthly and yearly average it is easy to identify when the SIP server was started and when we changed the RB1200 for a RB1100AHx2 (a week ago).
I’ve running my setup with an RB1100Ahx2 for some time now. Network performance has improved, but I think it still has place for improvement.
/tool profile shows
NAME CPU USAGE
snmp all 0%
ethernet all 3.7%
console all 0%
firewall all 10.7%
winbox all 0.2%
management all 0.2%
idle all 78%
profiling all 0%
queuing all 6.7%
unclassified all 0.2%
So I guess it should perform very well, as it is idle most of its time. However I suspect that when the number of packets increases (see graphs), performance suffers.
Most of the packets come from a sip server handling more than 500 concurrent calls.
Any idea on how to make the sip server not impact so severely the rest of the services?
