High 'networking'-load with IPSec using CCR2004
I’m using a CCR2004-1G-12S+2XS router for site-to-site VPN using IPSec.
Unfortunately, data transfer seems to be limited by cpu.
A file copy using HTTP barely reaches 50MBit/s - the cpu1 of the CCR is at about 60% with roughly 40% networking.
In Firewall, a raw ‘no track’ rule is present and hits traffic.
However, the accept established, related, untracked filter rule on input also gets hit by traffic?!
Has anybody an idea how to reduce CPU-load when transferring a bigger amount of data using IPSec?
Thanks for any help.
All the best from germany!
Sascha
Is nobody using IPSec for site-to-site?
Are there any better ways I’m not aware of?
If you have a CCR2004 at both ends, make sure to enable proper AES hardware acceleration for IPsec:
https://help.mikrotik.com/docs/display/ROS/IPsec#IPsec-Hardwareacceleration
It doesn’t have to be CCR2004 on both ends.
Just make sure to use encryption method which can be HW offloaded. Period.
Yeah, and to be more specific – if either end of the IPsec tunnel doesn’t have AES hardware acceleration, that’s going to set the limit for the total throughput you can get.
Exactly.
There is always a bottleneck.
And if the choke point is someplace where you have zero control over, you’re done. Nothing will help then unless you completely redesign the complete chain (at which point there will be another bottleneck elsewhere).
