I have just installed this Mikrotik and had complains from VPN users that they had a lot of drops out.
On inspection I found that the router is showing a high latency and packet loss. The line has been tested and is working fine.
The results of my ping tests are below - I have tried other addresses too.
My CPU usage is normal around 10% and there is no complex set up. Just standard NAT rules for port forwarding (mail, pptp vpn).
I noticed that I was missing a mangle rule on my other users they have 2 mangle rules. It must have been deleted by mistake so I have manually re-created it.
Would this cause an issue?
HOST SIZE TTL TIME STATUS
8.8.8.8 56 58 163ms
8.8.8.8 56 58 167ms
8.8.8.8 56 58 163ms
8.8.8.8 56 58 162ms
8.8.8.8 56 58 160ms
8.8.8.8 56 58 144ms
8.8.8.8 56 58 153ms
8.8.8.8 56 58 155ms
8.8.8.8 56 58 149ms
8.8.8.8 timeout
8.8.8.8 56 58 155ms
8.8.8.8 56 58 159ms
8.8.8.8 56 58 164ms
8.8.8.8 timeout
8.8.8.8 56 58 151ms
8.8.8.8 56 58 157ms
8.8.8.8 56 58 145ms
8.8.8.8 56 58 160ms
8.8.8.8 56 58 166ms
8.8.8.8 56 58 182ms
sent=20 received=18 packet-loss=10% min-rtt=144ms avg-rtt=158ms
