I’ve 2 APs in a RB532. Sometimes the users have extremely high pings, while they are pinging the AP. I have firewall filters with a lot of ports denied (same like the demo2.mt.lv mikrotik).
What should I do? Which other ports should i disable? Local traffic is already disabled, and also ports 135-139 and 445 both tcp and udp protocol.
I had the same after a fresh install of 2.9.12 (ping with 15000ms delay i switched back to legacy wireless and it’s gone…
(foward is on and cables were not changed/moved)
