High pings on wireless interface!Need Help
Hi everyone,
I had troubles with my MT wireless Access Point!
All work is about an RB and 2 radios (CM9 & R52). When there is only one client on interface the ping is work fine and stable, but when there are few clients on interface the ping becomes very high (<1000ms) and unstable.
I read on this forum that I should prioritize the ICMP traffic(packets) to get stable pings, but I don’t know how to do it and I don’t know is it the right solution?!
Thanks a lot
yes,
you must have ambulance traffic, same mean put your icmp with highest priority than other traffics. this methode will stable pinging when your network is overloaded.
soultion:
mangle and queue tree your icmp protocol will help you.
regards
Hasbullah.com
