High Power Wirelss Card on RB5XX and R1XX
I was try to install SR2 or SR5 on RB112 with 18V-2A power supply , I can see the card in /driver print
but its not shown in /in wi print
I’m replace the board by use RB532 with same POE 18V-2A , fully work , i try to install other card on MiniPC2 , same problem above , i was replace the POE use 48V DC injector , problem still.
I have question any body can can help me to install 3SR2 and 2RB52 for wireless distributed system as shown below with Router Board RB532 with RB564,
MainISP <---->5Ghzlink<---->MYBOX1<------5GhzLink----->otherBOXs
______________ 3 wireless Cards SR2 for 2.4Ghz links Clients
by the way i was replace the SR2 with 3 RB52 is work.
You can only put 2 SR2s on MT 532 board. Anything more and the board can’t power it.
Sounds like you also have a bad slot maybe on one:
Dennis Burgess
St. Louis Network Engineering Services
http://www.mikrotikconsulting.com
dmburgess@mikrotikconsulting.com
Certified Mikrotik Engineer
