high RTT with nstreme
hi there!
i know a lot of threads existing here regarding high RTT under nstreme.
is there an final recommendation under nstreme to have a stable average
RTT?
of course i can just simple disable nstreme… the qestion is, is there an possible workaround to use nstreme while have an stable low RTT?
thanks for any response.
btw: hw on both ends are rb532a and 2.9.41.
chris
Just pls to mention of what:
-wireless radio;
-what type of antenna;
-how many km to p2p or p2mp
my recommendations are:
-just follow the documentation from Mikrotik documentation as well as search for nstreme in all forums;
-using 48v power supply
-(maybe) using combination of ap/ap-bridge with wds-station using static wds-mode, pls do not using station because of 802.11 limitation
one more thing, a lot of useful advice for your case to resolve in forum.mikrotik.com. I believe you will find in these forums.
