Hi …
I’ve been playing with RSL graphing on wireless interfaces.
I created some ‘functions’ according to some examples around the forum to get the received signal from Mikrotik MIB for several clients.
Worked ok, I can see the graphs but only at the data source tab under Charts. And now? Where can I create those graphs? Are they only visible under Charts > Data Source?
BTW … after log in remote, the client speed is low as usual, something between 3K … 10Kbps.
After opening some of those data sources, the speed jumps to 850Kbps, dropping sometimes to 200Kbps. To stop this traffic, it’s necessary to log off and log in again.
Any help is apreciated;
regards
