high speed Hotspot router
I am looking for the best router for hotspot service. The customer has a 200Mbps FDX internet connection. I installed a RB2011 but running the hotspot server on it seems to cut the speeds down much to low.
Will a CCR work any better?
I would recommend a RB1100AHx2 before going all the way with a CCR. Look at the performance data and compare to the RB2011.
How many concurrent users expected on the hotspot
Thanks for the help.
Turn out that the rb2011 has an issue where anything on the gigabit ports is limited to a little over 20 Mbps on any gig port other than the wan port.
  • RB800
  • RB1100AHx2
  • CCR1009
  • CCR1016
depending on how many WLAN APs and clients must be sorted and served.
