I have a few links that have ccq both Tx/Rx in the steady 90’s, running btest from radio to radio in a ptp bridge setup with NV2, N-only, I get 80-100Mbps thoughput. (I know running on the radio is less than ideal due to cpu load) Running btest from a pc through the same link to the endpoint radio my bandwidth is down around 30-40Mbps… I have both setup in bridge mode, no firewall, nv2 preshare key aes wpa2. I am leaning towards an MTU issue perhaps.?.?
I also have a dumb question, maybe someone with more knowledge can enlighten me. If I have a ptp bridge is it possible or practical to disable ack on it being there’s no routing taking place on the link… or is there something happening on a the 802.11 plane.
