Hijacking packets to different server, possible?
Hi, I’m yhinking about this trouble but I have no idea how to solve it…
I’m using a TCP server (192.168.1.10) on port 5700 receiving packets from external networks (192.168.2.0/24, 192.168.3.0/24).
I’ve made a new TCP server (192.168.1.11) listening on port 5900.
I can’t do NAT on main router.
So I was thinking about placing a RB750 (IP address 192.168.1.10) making an internal NAT: 192.168.10.1:5700 re-directed to 192.168.1.11:5900.
Is it possible?
I also could make the second server on a different network and place RB750 as simple router, but this would be last solution.
I would like change src-address and dst-address at the same time or make multiple NAT on several IP addresses in the RB750.
ether4: IP addresses 192.168.1.10/24 and 192.168.20.1/24
1th NAT: dst-nat 192.168.1.10:5700 → 192.168.20.1:5800
2th NAT: dst-nat 192.168.20.1:5800 → 192.168.1.11:5900
but running Wireshark on server I can’t see incoming packets…
What’s wrong?
Thanks.
