Hi
I’m looking for some assistance solving an odd problem I have with a Home AP setup.
I’m using a mikrotik as a wireless access point using the latest stable RouterOS. I have a netgear N300 as a the adsl modem and the mikrotik wired to the N300 and set to use Automatic mode.
I’m able to ping any IP address from the mikrotik wireless (eg 8.8.8.
but DNS fails immediately. I’m completely new to RouterOS and so I have no idea how to diagnose the issue. Any help would be greatly appreciated.
connect using Winbox, open a New terminal, and issue:
/export
Then copy & past the output here.
Unless you provide more details like that, and the netgear config details it will be impossible to help you.
Thanks for your response.
I'm not sure what specifics I can give you about the netgear other than to say I'm using the most basic ADSL2+ setup. It isn't set up in bridge mode because I have other AP's attached to it. There is no QOS enabled on it no access control. Is there anything in specific you would need to know about its configuration?
The following is the output from /export:
/export
jun/06/2017 22:35:38 by RouterOS 6.39.1
software id = 5R8T-NELP
add admin-mac=E4:8D:8C:99:60:DB auto-mac=no fast-forward=no name=bridge-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce
country="south africa" disabled=no distance=indoors frequency=auto mode=
ap-bridge ssid=Wireless wireless-protocol=802.11
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=
ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=
ether5-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=
"" wpa2-pre-shared-key=
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp ranges=10.25.5.3-10.25.5.254
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=
bridge-local name=default
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
/interface l2tp-server server
set caller-id-type=ip-address
add address=10.25.5.1/24 comment="default configuration" interface=
ether2-master-local network=10.25.5.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no
interface=ether1-gateway
add address=10.25.5.0/24 comment="default configuration" dns-server=
192.168.88.1 gateway=10.25.5.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="default configuration" protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=
established,related
add action=drop chain=input comment="default configuration" in-interface=
ether1-gateway
add action=accept chain=forward comment="default configuration"
add action=drop chain=forward comment="default configuration" connection-state=
invalid
connection-nat-state=!dstnat connection-state=new in-interface=
ether1-gateway
add action=masquerade chain=srcnat comment="default configuration"
out-interface=ether1-gateway
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge-local type=internal
add interface=ether1-gateway type=external
/system clock
set time-zone-autodetect=no
/system identity
set name=Mikrotik
/system leds
set 0 interface=wlan1
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=wlan1
/tool mac-server mac-winbox
add interface=wlan1
You need to change dns-server parameter on DHCP:
add address=10.25.5.0/24 comment=“default configuration” dns-server=> 192.168.88.1 > gateway=10.25.5.1 netmask=24
and set it to your LAN IP:
add address=10.25.5.0/24 comment=“default configuration” dns-server=> 10.25.5.1 > gateway=10.25.5.1 netmask=24
Thanks very much, that solved the issue.
