Fozzie
September 25, 2024, 5:53am
1
Hi
I have a L0009 Router, OS Version 7.16. Have installed container as per instructions on Mikrotik page
https://help.mikrotik.com/docs/display/ROS/Container+-+HomeAssistant
All goes well until I try to obtain the Home Assistant image.
2 x Directories are created on USB1: USB1/ha and USB1/pull
If I watch the files folder, I see a compressed file arrive, but it does not extract and then deletes.
See error messages.
: failed to extract layer
: was unable to import, container 39b06245-a1f2-4020-bf23-387c705f96d1
Have tried 3 different USB sticks just in case, 128gb and 2 x 256gb but nope
I have since changed File system to EXT4, and now have a new message
failure: could not add
Any advice appreciated.
Fozzie
September 26, 2024, 8:05am
2
Hi
See error messages.
Problem solved. The usb drive was a micro sd card in USB adaptor, swapped to a dedicated USB stick, formatted to ext4, and it is now unpacking.
patrikg
September 26, 2024, 3:26pm
3
Hi, I’m very glad you solved the problem, but I and the forum would be so much happier
if you also mark your case in this forum as solved.
See the pictures below.
Where you click on the following places on the thread that solved your problem.
So the AI can take over and know what the problems are with the respective solution.
At board style: Canvas
At board style: prosilver
