Home network using RB450G pls HELP!
I want to connect my 2 computers to the internet using RB450G. Is there any manual how to set it up and what to do with the IP addresses of my PCs?
I simply connected the RB450G ether1 to my Modem, and the two PCs to the RB450G ether2 and ether3, but cannot connect to the Internet. Please let me know what I should do?
thanks
You will need to set up your WAN port on ether1 (DHCP client or static), bridge ether2 and ether3 and set up your LAN on the bridge, install a default route if you’re using static WAN addressing, set up NAT from LAN to WAN (masquerade) and probably a DHCP server on the LAN
The official manual is on a wiki, there are topics for all those things available:
http://wiki.mikrotik.com/wiki/Category:Manual
Is there a step by step instruction for setting up a Mikrotik router at home? I am a true dummy and do not know anything.
http://wiki.mikrotik.com/wiki/A_script_to_set_up_WAN/LAN/WLAN_to_get_you_started
There may be other user contributed tutorials.
http://forum.mikrotik.com/t/basic-router-setup-guide-tutorial/33155/1
Other forum thread with same question and many links.
