Hey All,
So I signed up for Azure 30day free trial. Loaded a CHR on their London data centre. Connected my AC2 via Wireguard. Set a mangle rule to divert all traffic from certain devices to the London CHR so I can access UK geo bound services.
Outcome? Ping all websites just fine. Can load simple webpages just fine, google, whatismyip, w3cschools etc great. But anything else is a nightmare. Can’t do speed test, can’t load itv.com or bbc.com properly.
HOWEVER If I install the Wireguard app on my android phone, connect direct to the London CHR. All is gravy, everything works as it should can do speedtest, load all the websites and watch the rugby, So why can’t I do this on the home network via the MK to MK WG link? Is it my mangle rule? Is it somthing todo with ports?
Config below for reference:
ROS 7.11.2
Home Router Mangle:
;;; UK Traffic
chain=prerouting action=route passthrough=no route-dst=10.30.30.2 src-address-list=UK-Traffic dst-address-list=!Local log=no
Really that’s it. As I said, WG tunnel works fine, and all traffic coming from UK-Traffic scr list is masq at the CHR end out of it’s WAN interface. I can ping dns address’s just fine, and simple websites work fine to, just nothing which is more comlicated.
If you need more info to go on I can provide. But perhaps there’s a special rule in routing via mangle I don’t know about.
Thanks in advance
