home router Dual wan and 3 vLANs
Ok, I have a 450g that I’ve been testing this setup with i loaded the dual wan setup from this page:
(https://aacable.wordpress.com/2011/07/27/mikrotik-dual-wan-load-balancing-using-pcc-method-complete-script-by-zaib/)
I’ve made some changes to it such as making all the ports bridges so I can just assign the ports to the proper labels i also assigned a dhcp client to WAN1 since one of my wans requires a dhcp. After adding in a dhcp server for the Local bridge for local clients all is well and I can get online… and this is where i break everything and need help completing the setup. Ive added 3 vlans to the bridge group local (IOT, TOR, and Default) The APs I have will handle adding the vlan tags to IOT and TOR but when it comes to the default or untagged vlan I can’t get an address or traffic to pass over it I know there is something missing but i’m not sure what thats why im here. I plan to move the config over to a custom build router x86 when this is up and working but till then the 450g is my testbed. Ive attached an export from the final stage of my test router . any help would be nice.
