Hey Guys,
So this is my first time Using Mikrotik and its proven more troublesome then I originally thought.
So I got myself A RB750 Just for testing purposes(Plan to use a old PC with ROUTEROS later in the future).
Anyhow so this is the setup I want to accomplish for now.
Ether1-WAN → Netgear Modem/Router(will update with the exact Model Number later)
Ether2-DHCP → Managed Switch with users
Ether3-Disabled
Ether4-Disabled
Ether5-Disabled
So my Idea is to connect my Netgear and RB using the WAN ports (Port 4 on my Netgear 1 on RB),
then dail up to ISP1 and ISP2 via PPPoe, And have a schedule that switches between ISP1 And ISP2 at certain times of day(6am-6pm ,ISP1,6pm-6am,ISP2) The schedule I have found a way to do so online. But the dialing up not.
I am using this link to try and set up a basic config : http://wiki.mikrotik.com/wiki/How_to_Connect_your_Home_Network_to_xDSL_Line
But I keep getting stuck at : Check if you have received IP configuration.
Mine either sits on connecting, or says disconnected.
Is that outdated? Or is there a setting i need to enable on either my RB or my Netgear for this to work?
I will gladly upload screenshots of my config if needed when I get home If needed.
And would also appreciate if anyone can Teamviewer in to assist if need be.
