Hello
im beginner with microtik.i need a configuration for my home setup
have 2 cap2nd and one RB952UI-5AC2ND.
how to set up properly for dhcp from router and the access points only to forward to client the dhcp from router.
is there any other configuration i can use?
thank you
Blocking DHCP from sources other than the Mikrotik requires layer2 security. Unfortunately, the only such feature that Mikrotik provides is client isolation - there’s a checkbox in the wlan interface configuration “Default Forward” - disabling this enables client isolation within a given access point. To completely enforce client isolation, you must be running your LAN via a bridge, and have interfaces dedicated to each WAP. Setting those interfaces with split horizon bridging will do what you want. (set horizon={any value} - use the same value for all such ports, and they will be blocked from communicating with each other.)
Do realize that you will not be able to communicate with other wireless-attached devices - for instance your smartphone apps won’t be able to see smart devices / set top boxes / etc to control them. You won’t be able to communicate with wireless-attached printers, etc etc etc.
