I have bought 40 numbers of RB260GSP to power and network honeywell cameras . (HIVDC-1600TVI) That POE switch RB 260GSP is not compatible with Honeywell cameras. powering is not functioned through poe port. if we give 12 V DC with1 amp adator through the power jack provided in the camera it will work. but not throught the RJ45 jack. i have connected a cat 5e cable to the poe switch and other end of the cable i have taken out blue and brown white wires from the eight wires present in the cat 5 e cables and connected to a jack provided in the camera and all other wires has been crimbed straight putting two demmis at the place of blue and brown white wires. then the camera works, that means data is transmitted through the poe port available in the camera and power is given to the camera through the power jack available in the camera through the same cat 5e cable from the same RB 260 GSP. it is also work fine with other brand poe swithches, please help us in this regard
mandatory features required for support to honeywell they say need. Apart from POE power, it should support IGMP, ICMP, Multicast, Snooping etc
