First I want to pretty much preface with what my goal is.. I work at festivals and we are sometime tasked with giving internet to office containers.. And we use to put NetGear routers out so that everyone in the office would have a feel that they were not on the same network as everyone else. this also made it easier for things like their printers to work and just have a more isolated experience then just joining a massive /20 network and stuff. Sometimes people ever bring in their TVs and want to cast to them and stuff.. But anyways the Netgears helped with that. BUT you lose management of them and they dont offer a lot of control.. eventually we moved to just putting APs in the offices but then those problems came back because I disable Multicast and broad cast on these wireless networks. so then people would need to add by IP and it would just be a ton of end user interactions and really slows down the flow of things. So I was thinking why not use a Mikrot HAP and just set it up to pick up the internet on a VLAN so there is also no native VLAN on the cable running into the office because ALSO!! people like to bring in their own switches sometimes and sometimes that causes loops etc.. if they get a DEAD cable where the native (untagged) traffic gets no internet.(also ccming from the uplink cable we would have BPDU guard and loop protect enabled.) it would deter them from he unmanaged switches.. this way I can remotely monitor the HAPs.. add queues if needed.. if they do loop things it will closed off the network of the HAP..
But I was test things.. and I mean the wifi speeds were just horrible.. on the cable I got the 90/90 which is expected on a 100 MB uplink.. But on the wifi it was horrible. anywhere from 30/20 to 50/20 to 20/50. just all over the place and never good.. and that is which fast track enabled.. I will post my config and maybe someone can help me understand if I configured something wrong. Im not a big Mikrotik wifi guy.. I main use ubiquiti but im decent with Mikrotik stuff. I use their routers and switches.
Ill also add that ive already order a bunch of AX2 thinking that maybe the HAP AC Lite is just not a good wifi device??? I dont know.. but its dual band with 5gz.. I was expecting better.. and I was super closed to router.. 10 ft and less during some other test..
add comment=defconf name=bridge port-cost-mode=short
set [ find default-name=ether1 ] name=ether1_WAN1
/interface vlan
add interface=ether1_WAN1 name=130_Ether1_ISP vlan-id=130
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=Eth1-Vl130
add name=WANS
add name=WANs
add authentication-types=wpa2-psk mode=dynamic-keys name=BigRed supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] country="united states" disabled=no mode=ap-bridge name=wlan1-2.4 security-profile=BigRed ssid=BigRedHAP10.90-2.4
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=20/40/80mhz-XXXX country="united states" disabled=no distance=indoors frequency=auto mode=ap-bridge name=wlan2-5G security-profile=BigRed ssid=BigRedHAP10.90-5G
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/snmp community
add addresses=::/0 name=bigredsnmp
/interface bridge nat
add action=accept chain=srcnat
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1-2.4 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2-5G internal-path-cost=10 path-cost=10
set udp-timeout=10s
set discover-interface-list=all
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add comment=defconf interface=130_Ether1_ISP list=WAN
add interface=130_Ether1_ISP list=Eth1-Vl130
add address=10.10.10.90/23 interface=ether1_WAN1 network=10.10.10.0
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=10.0.0.0/8 list=PrivateIPs
add address=172.16.0.0/12 list=PrivateIPs
add address=192.168.0.0/16 list=PrivateIPs
add address=192.168.88.0/24 list=NOTAuthorized
add action=accept chain=input comment=AllowAuthroizedALL src-address-list=Authorized
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment=AllowAuthroizedALL src-address-list=Authorized
add action=drop chain=forward comment=DropOutPrivateIPS-Ether1 dst-address-list=PrivateIPs out-interface-list=Eth1-Vl130 src-address-list=NOTAuthorized
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip ipsec profile
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=4222
set api disabled=yes
set api-ssl disabled=yes
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/snmp
set enabled=yes trap-community=bigredsnmp trap-version=2
/system clock
set time-zone-name=America/New_York
/system identity
set name=BigRedHAP10.90
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.windows.com
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
