Ether 1 is your WAN this must you connect with modem ore router from your provider.
Ether 2,3,4,5 have standard configured a DHCP-server.
Connect the client to ether2,3,4,5
But I still have this question of why does my host connected to ether1 gets an ip in the domain of 169.254.0.0. This tells me that ether1 is indeed running a DCHP server in the 169.253.0.0. Is that correct? If so, why dont I see this DHCP server when I select DHCP servers in my winbox.
Occasionally you may encounter a host which has somehow assigned itself an IP address in the 169.254.0.0/16 range. This is a particularly common symptom of Windows machines which have been configured for DHCP but for whatever reason are unable to contact a DHCP server. When a host fails to dynamically acquire an address, it can optionally
assign itself a link-local IPv4 address in accordance with RFC 3927. Microsoft’s term for this is Automatic Private Internet Protocol Addressing (APIPA).
Short for Automatic Private IP Addressing, a feature of later Windows operating systems. With APIPA, DHCP clients can automatically self-configure an IP address and subnet mask when a DHCP server isn’t available
