I'm setting up a lab in for our Office. For some reason, hosts can't ping outside their network but the MikroTiks can. All MikroTik devices are using RouterOS 6.
Host is connected to ether1.
An Ubiquiti Device to ether24
MikroTik Devices to ether19 thru ether23.
Host is attempting to ping 10.50.50.0/24 network (10.50.50.1 and 10.50.50.198 specifically).
Host IP is 192.168.89.2/24 + GW 192.168.89.31
FULL CONFIG
[admin@MikroTik] > export
may/17/2022 11:15:16 by RouterOS 6.46.1
software id = KWDC-246G
model = CRS125-24G-1S-2HnD
serial number = 49C804C57629
add name="MGMT Bridge"
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
disabled=no distance=indoors frequency=auto installation=indoor mode=
ap-bridge ssid=MikroTik-92289D wireless-protocol=802.11
set [ find default-name=ether1 ] comment="Maintenance Computer"
set [ find default-name=ether19 ] comment="MGMT 750GR 02"
set [ find default-name=ether20 ] comment="MGMT 750GR 01"
set [ find default-name=ether21 ] comment="MGMT 750GL 03"
set [ find default-name=ether22 ] comment="MGMT 750GL 02"
set [ find default-name=ether23 ] comment="MGMT 750GL 01"
set [ find default-name=ether24 ] comment="GATEWAY: DREAM MACHINE"
/interface vlan
add disabled=yes interface="MGMT Bridge" name="MGMT VLAN" vlan-id=99
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no name=defconf
add bridge="MGMT Bridge" interface=ether23 trusted=yes
add bridge="MGMT Bridge" interface=ether22 trusted=yes
add bridge="MGMT Bridge" interface=ether21 trusted=yes
add bridge="MGMT Bridge" interface=ether20 trusted=yes
add bridge="MGMT Bridge" interface=ether1 trusted=yes
add bridge="MGMT Bridge" interface=ether24 trusted=yes
add comment=defconf list=LAN
add address=192.168.99.31/24 comment="MGMT VLAN" interface="MGMT VLAN" network=
192.168.99.0
add address=192.168.89.31/24 comment="MGMT Bridge" interface="MGMT Bridge"
network=192.168.89.0
/ip dhcp-client
DHCP client can not run on slave interface!
add disabled=no interface=ether24
set allow-remote-requests=yes
/ip dns static
add action=accept chain=forward dst-address=0.0.0.0 in-interface="MGMT Bridge"
out-interface="MGMT Bridge" src-address=0.0.0.0
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=
out,none out-interface-list=WAN
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=
33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6"
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6"
dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
/system clock
set time-zone-name=America/Chicago
/tool mac-server
/tool mac-server mac-winbox
ROUTES:
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 10.50.50.1 1
1 ADC 10.50.50.0/24 10.50.50.198 MGMT Bridge 0
2 ADC 192.168.89.0/24 192.168.89.31 MGMT Bridge 0
